10" lift coils - Ford Powerstroke Diesel Forum
Old 10-30-2008, 12:02 PM
10" lift coils
Looking at 10" of lift with adjustability. Originally, I was thinking coil overs, and still am, but with the cost, I'd like to look at all of my possibilities. I know Fabtech and Superlift make a 10" lift with standard coils up front. Do either one of these use a 10" lift coil, or are they 8" lift coils and a 2" spacer?
Next option would be to have a set of coils made. The only question they asked was what the OEM# for the front coil was. I'm guessing to check spring rates and size. So does anyone have that number for a 2008 F-250 Crew Cab 6.4L auto FX4 with no special HD option (no ambulance package or upgaded capacity springs)?
Old 10-30-2008, 03:35 PM
The Fabtech system utilizes 10" coils. However this will not provide you with adjustability. Only coil-overs will allow for this.
Old 10-30-2008, 03:53 PM
Funny, my Fabtech 10" setup was 8" coils and a 2" puck.
I thought that the only 10" spring was superlift.
Old 10-30-2008, 04:00 PM
The app guide calls for 10" coils but we don't use Fabtech much for SD applications so I could be wrong.
Old 10-30-2008, 04:01 PM
Yeah the Fabtech stuff is only 8" coils...just like the RIZE only has 8" coils
Old 10-30-2008, 04:08 PM
Coilovers
Old 10-30-2008, 10:31 PM
True, but with 10" coils I can add a 1 or 2" spacer to add a little lift and still be safe.
Thanks Pahrump. This is why I didn't want to just go by what their website says, because a lot of kits have "coil assembly or coil kit". I would hate to run a 8" coil and a 4" spacer.
So does Superlift have a true 10" coil?
Old 10-30-2008, 11:06 PM
Fabtech is a 8" coil w/2" bottom spacer.
Superlift is an actual 10" coil spring that is available now.
Old 10-31-2008, 05:53 AM
I actually have a set of Rize 8" coils that are sitting in my warehouse, I'll sell them to you for $200 shipped there really heavy. If you want them let me know.
Old 10-31-2008, 06:07 AM
Thats a good idea, I had the same one....but I was told by TopGuns, and Marty@ TruckToys that 10" is the most you can do without steering and probably drivetrain mods.
