| 6.4 Exterior Discussion Body and Accessories Talk |
20inch black Rockstar Pics?
I want to get some Rockstars for my truck but will be running the stock Ford 20 inch tires till spring. Does anyone have pics of there truck with black Rockstars with the factory 20's? I am not sure if it will look funny with them on there until I get a little wider tire. I am not planning on lifting the truck and I tow with it so I don't plan on going crazy with big wide off road tires.
Thanks Tucker |
It will look fine.
Pahrump,
The first time I saw the Rockstars was on your truck, and that was when I made up my mind that was what I wanted for my truck. |
I can get you a pic of some with 33s on them, a friend...well...acquaintance has them on a Chevy...should be close to stock size tires.
If that would not be to much trouble, I would appreciate it.
Thank You |
FYI, we offer 20x8.5 Rockstars with 5.14" backspacing in 8x170mm. These would probably fit your application better than the more tyical 20x10 with 4.56" backspacing.
......Now if they look Pahrump's they look badazz, but just my two cents.......think you should find a pic them firstHere are Jmarts and these are 20x10s so this should be a reference ![]() I know they aren't 20's but here are some stock sized rockstars on an F150 18x9
But that is alot less agressive tire? I want to do the same on mine. I love the rockstars but don't like that silver star (imagine that from a cowboy fan) can you get them without it or blacked out? I have 18's now, want to go as big as possible without rubbing. I have a 2" leveling kit in the front.
I am running the 35's on mine with just a leveling kit. I run the 20x10 with the 4.56 backset. They dont stick out to far.
