Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 10-02-2008, 12:55 PM
boggs187 boggs187 is offline
Lug Pattern?
Is the new 2008 f-250 lug pattern the same as a 2002 f-250? Thanks
Old 10-02-2008, 12:56 PM
bockhold bockhold is online now
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
i wouldnt think a lug pattern would change at all
Old 10-02-2008, 01:08 PM
broke college kid
now what i think would change might be the torque
Old 10-02-2008, 01:23 PM
DunesRunner08 DunesRunner08 is offline
The lug pattern is the same.... the backspacing is different.... the new one runs either a 5" or 5.5" backspace where as the old one was 4-4.5" backspace.... but most aftermarket wheels will be interchangable...
Old 10-02-2008, 04:42 PM
dpbuckster dpbuckster is offline
Just FYI, the older 8-lug Fords are 8x6.5 and the 99+ are 8x170mm. They changed to a metric bolt pattern, but 99-08 should be the same as far as bolt patterns go.
Then there's the 10-lug for the big boys, but I don't remember the specs on those.
Old 10-02-2008, 05:53 PM
ford99PSD ford99PSD is offline
coul ya possibly put the 08 rims on the 99-07 trucks. i dont understand backspacing
Old 10-02-2008, 06:19 PM
DCSpecial DCSpecial is offline
Supporting Vendor
As mentioned 99-08 SRW SDs have a 8x170mm bolt pattern.
99-04 450/550s had 8x225mm
05-08 F-350 DRW has 8x200mm
05-08 F-450/550 have 10x225mm
99-02 used 14mmx2.0 studs
03+ used 14mmx1.5 studs
(size is the same....thread pitch is different).
You can bolt 05-08 wheels on a 99-04, but they will sit under the truck and most likely the tires will contact the leaf springs while turning unless you use wheel spacers to account for the increased back space on the 05-08 wheels.
With the wheel spacers they will look normal under the truck and you won't have any issues turning.
Old 10-02-2008, 08:31 PM
I almost posted that info Dan but saw that he only has a SRW so I figured it didn't matter.... but I didn't know the thread pitch was different.....
Old 10-02-2008, 08:48 PM
krazeehorse krazeehorse is offline
Backspacing is also referred to as offset. It is how much of the width of the tire and rim is behind where the wheel meets the face of the rotor and how much is outside of that. Remember old chrome "reverses"? The tire and rim stuck out from under the rear fenders. They were reverse or negative offset wheels. I think 2005 is when they started putting wheels with some positive offset on the superduties.
Old 10-03-2008, 09:11 AM
Supporting Vendor
Back Spacing and Offset are two different terms and two different ways of measuring a wheel.
But ultimately they tell you the same thing, and with one you can determine the other if you know the width of the wheel.
Good link with wheel tech info and terminology:
https://www.rsracing.com/tech-wheel.html
