Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #11 (permalink)
Old 09-23-2008, 10:34 AM
rollthecoal rollthecoal is offline
I have the FX4 package and fit Dick Cepek F/CII's in 35 x 13.5 on my truck with little to no rubbing even with major axel flex. You should have no problems
  #12 (permalink)
Old 09-23-2008, 10:56 AM
fsas fsas is offline
Go with the 35's! trust me...I've got pretty much the same setup except I have a leveling kit. I was a rookie when it came to wheels/tires too so I did the same thing when picking a package...I'm definitely gonna get bigger tires next time. I don't like the "rubber band" look of my setup.
  #13 (permalink)
Old 09-23-2008, 02:41 PM
6.4PowerStroke_08 6.4PowerStroke_08 is offline
i bought a ready lift leveling kit for mine and haven't put it on yet but does anyone else have this on a 08 with 35s? whats a good tire that wears good?
  #14 (permalink)
Old 09-23-2008, 03:04 PM
TxPSD9673 TxPSD9673 is offline
Originally Posted by po-po 5.0 View Post
The stock tire is 34" so a 35 isn't all that much bigger. Depending on what wheel you go with you might have some problems with the tire rubbing the radius arm at full turning lock. This will only happen if you go with a 12.5" wide tire with too much backspacing.
i doubt the factorys are 34s
bfg a/t will wear the best and last the longest
  #15 (permalink)
Old 09-23-2008, 06:04 PM
Well thats is what i had in mind but i don't think they make 35s for an 18 inch rim. I had BFG a/t on my f-150 and they wore good and went good off and on road. Plus they make the truck look better.
  #16 (permalink)
Old 09-23-2008, 06:13 PM
Eric Eric is offline
I HAVE POWAH!!!!!
There are several 35x12.50R18 choices out there
  #17 (permalink)
Old 09-23-2008, 06:15 PM
2005F250 2005F250 is offline
Make sure to get a positive offset on the wheel and a 35 will fit no problem.
  #18 (permalink)
Old 09-24-2008, 11:15 AM
DUstroker08 DUstroker08 is offline
I talked to a diesel mechanic at the local ford dealer about lifting an 08 and tires, and he brought up that he thinks its pretty stupid for these guys going out and buying 35s and paying over $1,000 for one more inch of tire. So i believe hes right they are pretty close to a 35
  #19 (permalink)
Old 09-24-2008, 01:34 PM
Factory tires were roughly 34 x 11 on my truck. I had lots of trouble with them (Goodyears) to the tune of 6 flats within a couple of months - so swapped them out.
I have found that there are many more options in the 35x12.5 size for all-terrain and mud tires. What is available in P-metric tends to be highway tires, which are good enough for most.
  #20 (permalink)
Old 09-24-2008, 07:07 PM
My factory tires are 33.7 inches tall. They are 275/70/18 continentals and they suck.
