Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 09-10-2008, 09:07 PM
Xtreme Liner
Ok, so a while back I made a thread asking about what people did with their tailgate when getting a sprayed in bedliner. I figured I'd make a thread with what I did and include pics to give other people an idea. I also wanted to note that there are a lot of people in the Houston area looking for Line-X, which is no longer in Houston. The closest for me was Austin, and they were unwilling to make an appointment on the weekend, so I was out of luck with my work. After searching online, I decided to try Xtreme Liners of Houston, which Isaac had several praises for his work. He was even willing to setup an appointment on a holiday weekend to get my truck done. Hopefully, this will be a good alternative to Line-X, if not better.
I had the standard under-the-rail bedliner sprayed. As far as the tailgate goes, I took the handle off, pulled the bolts holding the plastic on, and had the entire tailgate sprayed. I can be quite picky at times, and wanted the entire bed to look the same...not have a sprayed bed and a plastic tailgate liner. Isaac was more than willing to work with me and thought it turned out very well. I have the tailgate handle and the bed extender thing, and everything bolts back into place and works just like it did before.
Here are some before and after pics, as well as some pics his wife graciously took while the job was being done. This will give everyone a good idea as to the process as well as what the tailgate looks like under the plastic liner. It is actually a standard tailgate with the access panel removed and a bracket bolted on to hold the handle.
One week later, my father and I made a trip to the deer lease, which saw some good use. After getting home and a quick spray down with the water hose, it looks good as new. I will try to make updates later down the road, to show how it holds up strength wise and color.
I highly recommend Isaac at Xtreme Liner of Houston if anyone is looking for a place to go. Xtreme Liners of Houston
All in all, I am extremely happy. The only thing I see that I do not like, is that the plastic liner is slightly wavy at the bottom of the tailgate, so I might go back and add two screws to keep it laying flat. It was like this before the bedliner, but wanted to make note in case someone noticed.
And just to note, I am not trying to sell bedliners, just show how mine turned out and hope to help someone else out there looking for one.
Enjoy
Old 09-11-2008, 08:02 AM
rXr rXr is offline
Great little write-up ... thanks for sharing this. I like what you
did with your tailgate!
Old 09-12-2008, 07:06 AM
rXr rXr is offline
So, I was going to do the Line-X thing ... and I too have been
having a hard time getting my truck in on a week day. Well,
after reading your write-up yesterday I decided to see if there
was an Xtreme Liner dealer near me. I found there is one
about 26 miles down the road ... and they will spray my truck
on a Saturday!
So, I got a couple questions:
Did you have them spray under the plastic area of the tail
gate, or just over the plastic and the exposed metal areas
of the tailgate?
How well do you think the liner will stay on the plastic?
Did they have to rough up the plastic?
Old 09-12-2008, 10:48 AM
I pulled the bolts off of the tailgate and kept the plastic tabs holding the plastic on to the tailgate. He sanded down the paint around the edges and sprayed everything that was exposed like a normal tailgate. So underneath the plastic, part of the metal is still painted like normal. I wanted it like this in case I decide to delete the handle down the road, I can get a regular tailgate access panel and bolt it on, then have the tailgate sprayed.
I don't believe he roughed up the plastic. I asked if he thought there was any chance that it might not stick as well, and he said the stuff would stick to anything and that it wouldn't be a problem. So far so good. I figured if all else fails, the plastic piece couldn't be too expensive to replace, so I went for it.
Old 09-12-2008, 11:42 AM
rXr rXr is offline
Very cool!! Thanks for the info. Having mine done on the 27th
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
