What tires will fit - Ford Powerstroke Diesel Forum
post #1 of 25 Old 09-09-2008, 05:34 PM Thread Starter
zeddy's Avatar
What tires will fit
I would like to put a 2.5 Not the leveling kit but the 2.5 lift kit.
Has anyone done this? what size tires could I fit without trimming anything(on my stock 20" rims).
I was thinking 325/60/20 bfg at but they only show a 50psi rating, wont that set off my tps?
What to do?
zeddy is offline
post #2 of 25 Old 09-09-2008, 05:38 PM
Pahrump's Avatar
On your stock wheels you can probably get a 37x13.50 to fit with minor trimming.
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #3 of 25 Old 09-09-2008, 05:47 PM Thread Starter
zeddy's Avatar
To highjack my own thread....Are you on rhinoforums.net also?
zeddy is offline
post #4 of 25 Old 09-09-2008, 05:52 PM
JBHT's Avatar
What to do?
Do you have an '08? If so 35's will fit with no lift, so 2.5'' lift should get 37's
'08 F250 Lariat Crew Cab 4X4, 35x13X18 Terra Grapplers,Warn Power Plant on Warn Transformer, 5 gal air tank, AFE intake, Banks Monster Exhaust, Spartan 250
JBHT is offline
post #5 of 25 Old 09-10-2008, 06:26 AM
Overkill's Avatar
What to do?
I would not recommend running 37s under a 2.5" system. We run them under 4.5" systems occationally and IMO that is a tight fit. Furthermore, 37s on the stock wheels will exhibit considerable rubbing on the radius arms at near full lock steering.
Here are a few examples of 2.5" systems on 35s:
Bilstein 2.25" on 35s w/stock wheels
Icon 2.5" on 35s w/20x9 wheels
The tire pressure sensors will alert you under 65 lbs. but this may be recalibrated by your local dealership.
Overkill is offline
post #6 of 25 Old 09-10-2008, 01:03 PM Thread Starter
zeddy's Avatar
Can you recalibrate them your self with the service tool?
thanks for the pics, what 6 inch kit would you reccomend?
Also if I do 37's with a 373 rear end should I consider regearing or should I be ok?
zeddy is offline
post #7 of 25 Old 09-10-2008, 01:30 PM
Pahrump's Avatar
Yes I am...as well as on many other auto, and atv forums with the same name.
Black C6 Vette
Pahrump is offline
post #8 of 25 Old 09-10-2008, 06:14 PM
6.4PowerStroke_08's Avatar
I ordered a leveling kit for mine. its a readylift 2.5 What would be a good size tire for an 18 inch rim. does anyone have a readylift on there 08? post pics if you do. i can't decide what size tire put on there with the leveling kit.
2008 F-250 6.4 Powerstroke crew cab, Spartan, H-11 Studs, Spearco Intercooler with cold side pipe, 5 in Flo-Pro Exhaust 4in downpipe, No Limit Fab intake, RPM Offroad traction bars, Ready lift 2.5, Fab Four Bumper, EBC rotors with Hawk pads, UWS low profile toolbox rhino lined, T-Rex Billet Grille, Recon Cab lights, Remote Start and Alarm system, 2 10"in Rockford Fosgate & 1400watt Diesel Audio amp
6.4PowerStroke_08 is offline
post #9 of 25 Old 10-29-2008, 09:19 AM Thread Starter
zeddy's Avatar
Well I pulled the trigger!
A bit different from my original plans but I dropped the truck off this morning for a 6 inch fabtech lift with radius arms and a little extra lift in the back and 37x12.5 xtreme m/t on the factory 20"wheels
Cant wait to see what it looks like.
When one of my neighbours pointed out how much my mileage would drop I responded by saying, I'll do the exhuast and intake to recoop my losses. My wife thought it was a good idea...I love her!
also I ordered bushwacker flairs. Should be like a new truck! Then I'm gonna drop it off for it's first oil change!
2008 F350 cc lariat 6.4-my first diesel!
6" fabtech
37" procomp xtreme mt
Nosey little prick aren't you!
zeddy is offline
post #10 of 25 Old 10-29-2008, 11:14 AM
Overkill's Avatar
I have not found a service tool that will allow you to recalibrate the tps. As far as I know this can only be done by the service department.
Here are a few of the high quality 6" systems we offer all of which are backed by lifetime warranties:
Rize Industries 6 Inch Radius Arm Front System - 2008 F250/F350 SRW - 2008 F250/F350 SRW 4wd - Truck Toyz Store
BDS 6 Inch Radius Arm Suspension System - 2008 F250/350 SRW 4wd - 2008 F250/F350 SRW 4wd - Truck Toyz Store
BDS 6 Inch 4-Link Suspesion System - 2008 F250 Superduty SRW 4wd - 2008 F250/F350 SRW 4wd - Truck Toyz Store
RCD 6 Inch 4-Link Suspension System - 2008 F250/350 SRW 4wd - 2008 F250/F350 SRW 4wd - Truck Toyz Store
Rize Industries 6 Inch Quad Link System - 2008 F250/F350 SRW - 2008 F250/F350 SRW 4wd - Truck Toyz Store
And here are a few examples:
Overkill is offline
