Moisture Problem in Headlights - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-28-2013, 08:44 PM Thread Starter
So I purchased a set of headlights from a forum member that were seperated and the inside bezel painted black and then sealed back together. I've had them for about 2 months. It just started getting chilly and we had a lot of rain last week.
Now both my headlights show moisture and foggyness real bad. To the point of embarassment. It does seem to dissipate some when the headlights are on, but not completely and the moisture comes right back.
Is there anyone local to South Florida area that could give me a hand at maybe seperating and resealing these lights so this wont happen or have a good idea for me to try on my own? I just dont want to ruin the lights beyond repair.
2008 Black F250 6.4 - Long Bed XLT
8" Fabtech, H&S Mini Maxx (Hot Damn), 4" aFe Exhaust, Downpipe, Cold Air Side Pipe, aFe Intake, Flo-Pro Emissions Delete
BigNiner19 is offline
post #2 of 4 Old 12-02-2013, 10:50 PM
tony97gt's Avatar
Where in south fla are you? It's REALLY simple. Order this and we can go from there. http://www.theretrofitsource.com/pro...roducts_id=792
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #3 of 4 Old 12-02-2013, 11:02 PM
tony97gt's Avatar
The way this guy did it, is exactly how I did it. Just be careful with the plastic tabs when you're prying apart, they break very easy since the plastic will be warm. If you find that the glue isn't budging, put them back in the oven for a few mins to soften it up again. All the housings are is two pieces of plastic that have a strip of black glue in between them. The oven softens up the glue enough so you can pull them apart. Once apart, clean out the channel where the glue is just by picking with your finger and a small screwdriver, or using a razor to slice out the old glue. Once it's all clean, lay the butyl tape in the channel and put them back in the oven and you're done.
tony97gt is offline
post #4 of 4 Old 12-02-2013, 11:17 PM
tony97gt's Avatar
Painting Headlights
tony97gt is offline
