Outside Hidden CB Antenna - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-20-2013, 05:05 AM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
I was just curious on different places everyone have mounted their CB antenna's. I would like to keep it hidden. I know it will reduce the length it will reach and I'm ok with that. Let me know what you've done. Thanks!
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #2 of 12 Old 11-20-2013, 05:12 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Check these out-http://www.amazon.com/K40-K40A-57-25-Antenna-Stainless/dp/B000FSADEA/ref=sr_1_2?ie=UTF8&qid=1384956603&sr=8-2&keywords=k40
They have good transmit/receive. They are very strog and the great thing is you can just take off the main antenna part with just a twist and toss it in the truck.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 11-20-2013, 02:06 PM
That whip antenna wouldn't really meet his request for the antenna to be hidden.
This is actually one of my winter projects, I'm installing a CB radio and 2m Ham radio into a custom box between my center console and the dash. I'm going to replace the AM/FM antenna with a 2' or 3' Firestick CB antenna and use a AM/FM/CB splitter so it can pull double duty as both my CB antenna and my AM/FM antenna. If you did this few people would probably recognize that you have a CB.
I need 2 antennas, so I'll also mount a short black 1/4 wave antenna for the 2m radio on the roof near the 3rd brake light.
2008 F350 6.4L SCSB
Veteran and Lifetime DAV member
U.S. Navy Submarines 1997-2007
U.S. Army Pilot 2008-2010
Mr Hahn is offline
post #4 of 12 Old 11-20-2013, 02:07 PM
Walcott Radio is a good source for CB stuff, this is the splitter I was talking about: CLICK THIS LINK
2008 F350 6.4L SCSB
Mr Hahn is offline
post #5 of 12 Old 11-21-2013, 06:36 AM
What are you using as a base to replace the built in am/fm antenna? How difficult is it to get to the am/fm antenna plug in the back of the radio? What brand CB are you going to use? Sorry for all the questions.
2015 F250 Lariat SD FX4
6" Rough Country Lift
20" XD Series Wheels
37" Nitto Trail Grapler M/T
Stock
2008 F250 Super Duty 4X4
6" Pro Comp Lift
Pro Comp 6001 Wheels
Nitto 37" Terra Graplers
4" dpf/cat delete w/MBRP
SCT Tuner - Performance Tune
bsudkamp is offline
post #6 of 12 Old 11-21-2013, 08:33 AM Thread Starter
Quoted: 80 Post(s)
I have the Cobra 25 LTD, I have dual 3 ft Firesticks. Im thinking I can run the coax through the headrest to somewhere.
'08 F250
post #7 of 12 Old 11-21-2013, 11:00 AM
All of this is pretty simple if your comfortable taking things apart and have a basic knowledge of electronics and wires. I haven't started the project yet but I've done similar things on other vehicles. I'll post a thread about the install when I actually start working on it.
2008 F350 6.4L SCSB
Mr Hahn is offline
post #8 of 12 Old 11-21-2013, 02:00 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hey I got a idea for you guys....have you guys ever watched that submarine movie Cremson Tide? Remember when they reeled out the ultra low frequency antenna? You guys could get a steel whip antenna and when you want to talk you let it out from under the truck....when your all done reel it back in! It be hidden and work well.....may throw some sparks but who cares.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 12 Old 11-21-2013, 02:56 PM
y2kf350's Avatar
I'd also like a hidden antenna and just found this. It's meant for a Harley bike but I would think you'd be able to put it into a truck just as easy.
I have no idea how well it works though
J M Flexpower in Fairing Hidden CB Antenna Harley FLHT | eBay
2000 F350 CC 4x4 Dually
Lots of stuff done - lots more to do.
y2kf350 is offline
post #10 of 12 Old 11-21-2013, 06:05 PM Thread Starter
Quoted: 80 Post(s)
Originally Posted by y2kf350 View Post
Did some reseach, it wasn't coming out good. Found this on a motorcycle forum. Seem to be running into walls every direction. Haha.
Review of J&Ms new FLEXPOWER CB antenna - Harley Davidson Forums
'08 F250
