Amp Research Power Steps - Ford Powerstroke Diesel Forum
Old 07-31-2008, 10:36 PM
Who here has Amp Research power steps on there truck? I am looking for some measurements. When opened, what is the distance from the top of the step to the door seal or bottom edge of the truck? Also, if you have the 2" extension, does the step still fold to be flush with the truck, or does it stick out more?
I am looking into how much lift I can put on my truck without going beyond what's comfortable for a DD.
Old 07-31-2008, 10:51 PM
I have them on my 11" lift and no extension and they are perfect...but I am 6'4"...the 2" extension is good for bigger lifts but it will not sit flat against the truck...it sits 2" down
Old 08-01-2008, 03:54 AM
Thanks DunesRunner08. Could you measure how far down the step comes when they are fully extended? Like from the top of the step to the bottom of the cab? I am 5'10" and considering about 10" of lift and ~40's similar to your setup, but thinking that may be a tad high for my heavy self, lol.
Old 08-01-2008, 04:54 AM
I have the 2" extentions on my truck with just the 2 1/2" leveling kit, and mine go up flush with the truck when they are retracted. I have a prosthetic leg and they make it very easy to get into the truck.
Old 08-01-2008, 05:06 AM
Nice truck Fenwick. I checked out your gallery and while they do hang a little lower, they don't stick out like I thought they might.
Old 08-01-2008, 05:11 AM
Also, incase anyway was curious like me, I found this on Amp's site.
http://www.amp-research.com/pdflibra...ps_PSDrops.pdf
It says it's 13.5" from top of door sill to top of deployed step.
Old 08-01-2008, 06:44 AM
I wan them BAD.....but they are costly and I hear hard to put on......and I am not one to pay someone to do work on my stuff....something about they electrical being pretty technical....not to mention they are kinda expensive...lol
Old 08-01-2008, 06:52 AM
Thats Mr. Oil Leak.....
Here is a video of joe's (stroker~x) truck with the steps installed.
My AMP powersteps
Old 08-01-2008, 06:57 AM
Ole White
I did the Kodiak Sidewinder Eletric Steps and they work get and they come down 8 inches but can be bought in longer lengths if needed
Old 08-01-2008, 07:21 AM
the problem with the Kodiak steps is they use plastic gears and they break a alot....you always see them hanging off someone's truck where they didn't retract....but I do like them.....the AMP steps are very expensive and yes they are hard to wire in properly but its well worth it when it is done
