Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #11 (permalink)
Old 08-01-2008, 07:45 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
STAGE II's
Originally Posted by DunesRunner08 View Post
the problem with the Kodiak steps is they use plastic gears and they break a alot....you always see them hanging off someone's truck where they didn't retract....but I do like them.....the AMP steps are very expensive and yes they are hard to wire in properly but its well worth it when it is done
Have had mine for over 3 years and have had no problems maybe I've been luckily
  #12 (permalink)
Old 08-01-2008, 08:05 AM
CHenry CHenry is offline
Sooner Powerstroker
What makes these so hard to install?
How do they operate in winter when you get a huge iceball built up behind the front tires?
  #13 (permalink)
Old 08-01-2008, 08:43 AM
DunesRunner08 DunesRunner08 is offline
The AMP motor cuts out when there is pressure applied so as not to break like what happens with the Kodiaks....as for in the snow, I couldn't tell you because I am in Phoenix....lol... I did live in Buffalo for most of my life so I know a little about snow and I don't think it will be an issue.....the salt may become more of an issue than anything so just make sure you wash the steps off
As for the wiring, you need to wire into the door switch so they open and close with the door...its not like the Kodiaks with the pressure switch that you drilled a hole for, those break all the time
  #14 (permalink)
Old 08-01-2008, 10:30 AM
DCSpecial DCSpecial is offline
I have 3 sets of AMP steps on 3 trucks and live in northern IL where the roads are heavily salted and we get a good amount of snow.
I've never had any issues with the salt or the ice.
I do think that the diodes that AMP sends don't like the cold....need to try replacing them on the 05 F-150 before winter (passenger side step doesn't always open/close with door....only in winter).
They used different diodes back when I got the ones for my 01 F-350 and I used diodes from my buddy's shop when we installed them on my 07 F-350 so they both work flawlessly.
I've washed my 01 in the winter with -20* windchills and while ice was forming on the truck rather fast, I didn't have any issues with the steps (truck was covered in road salt...had to get it off).
They do send a wiring diagram with the steps, but finding the correct wire sometimes is difficult.
The 13.5" from the door sill to the step sounds right. I'll measure my 07 when I go back out to the shop after lunch.
  #15 (permalink)
Old 08-01-2008, 11:36 AM
Pahrump Pahrump is offline
WOW those are LOTS lower than my stock nerf bars.....make the truck much easier to get in for the wife....hell of a selling point
  #16 (permalink)
Old 08-01-2008, 03:40 PM
dpbuckster dpbuckster is offline
Yep, I'm thinking if I can get a nice set of steps that drop lower than the stock steps, I can lift the truck higher
My main concern at this point is, I'm curious as to how much weight they can hold from the bottom...as if you were to get high centered and set the truck on the steps.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
