wheel offset - Ford Powerstroke Diesel Forum
post #1 of 45 Old 07-01-2008, 06:33 PM Thread Starter
wheel offset
iam new to forum. i have a 08 f250 fx4 with 18s. i don't like the rims and want to replace them with some different 18's. my question is what offset should i go with. i want 18x9 and will put stock tires on and 35's later with small lift. thanks for help
markm is offline
post #2 of 45 Old 07-01-2008, 09:36 PM
smotrs's Avatar
First off, not saying you don't know but a minus offset will shift the tire out from under the vehicle, a positive offset will bring the tire back under the vehicle. So the larger the negative offset the deeper the wheel is and the more the tire will stick out.
Now that we got that out of the way, I have a similar tire/wheel size to what you describe. My wheel offset is -24 and they look like this on my ride
So if you go with something roughly around the same offset, you'll have a similar look. By the way, the offset is metric (mm).
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #3 of 45 Old 07-01-2008, 09:36 PM
smotrs's Avatar
Oh, and welcome to the board.
Shaun
Line-X bedliner
smotrs is offline
post #4 of 45 Old 07-01-2008, 10:55 PM
Dusten's Avatar
Quoted: 182 Post(s)
Garage
i wouldnt run the stock tires on a 9" wheel, its to wide.
2008 Ford F-250 - 6"-37s-H&S-deleted
2001 Ford Lightning - Built motor - Built trans - 2.3 KB - Custom Interior - Garage Queen
1993 Ford Lightning - stockish
1994 Ford Cobra - stockish
1968 Mustang - Gold Nugget Special - restored
2015 Chevy Tahoe LTZ
2015 Hyundai Sonota Sport
Dusten is offline
post #5 of 45 Old 07-02-2008, 02:27 PM Thread Starter
thanks guys.smotrs your truck looks good. I was thinking about a 18x9 0ffset rockstar or a +18 hoss on a 35x12.5 pro-comp extreme AT. dusten why can't I put the stock tire (275x70x18) on a rim thats only 1in. wider
markm is offline
post #6 of 45 Old 07-02-2008, 02:32 PM
willypscustoms's Avatar
pretty much to keep it under the truck youll want the rockstar that comes with 5" of back spacing the part # is xd77589087300
IF CAPS ARE ON IM AT WORK I CANT TAKE THEM OFF
willypscustom cold air intake
4" exhaust straight piped
banks 6 gun
itp regulated return
dp tuner
9" lift 37" tires
agr hydro. assist steering
greddy turbo timer and greddy gauges
wicked wheel
and some other small mods
willypscustoms is offline
post #7 of 45 Old 07-02-2008, 02:44 PM
These wheels are 20x10 with a +10 offset, running 35's.
F250 reg cab short bed
JMart is offline
post #8 of 45 Old 07-02-2008, 02:44 PM Thread Starter
willypscustoms that was exactly what I was looking at but Iam getting mixed reviews on wether that rim will work. Any feed back is appreciated. Thanks.
markm is offline
post #9 of 45 Old 07-02-2008, 02:49 PM Thread Starter
jmart that is what I want but with 18s. how do you like the ready lift. Is that the sst 2.5.thanks
markm is offline
post #10 of 45 Old 07-02-2008, 02:59 PM
It was the 2.5 full kit not just the front level. I like it, its really easy to install me and a friend did it in an hour and a half. I just wanted enough lift to clear 35's so this was my choice. This way I can still fit in the garage if I need to.
JMart is offline
