Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #21 (permalink)
Old 06-24-2008, 07:11 AM
Pahrump Pahrump is offline
THANKS!!!!!
  #22 (permalink)
Old 06-24-2008, 09:16 AM
dezl dezl is offline
your truck is beautiful man!
  #23 (permalink)
Old 06-24-2008, 09:27 AM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
Looks sick!!!
  #24 (permalink)
Old 06-24-2008, 09:38 AM
stunya stunya is offline
zeroone...how many miles on that rize kit now? any complaints?
thanks...
  #25 (permalink)
Old 06-24-2008, 10:04 AM
ZeroOne ZeroOne is offline
thanks...
About 12k miles. If I HAD to complain about something, it would be that the drop pitman was just a tiny bit too short, so there is a touch of bump steer. Its not enough to make the wheel go crazy, but you do notice the feedback. Besides that though, its perfect.
EDIT: wait, I just remembered one more thing. The sway bar drop kit (mounts to the frame) should have been notched where the intercooler tube passes it. It's rubbing at high levels of boost, but parked they're not touching.
  #26 (permalink)
Old 06-24-2008, 01:25 PM
Ok Pahrump, got the measurements. With the 9" OUO traction block in the rear, the truck sits pretty level with the front measuring 13 1/4" from the drivers-side axle bumpstop pad (front outer corner of it) to the seam between the trackbar mount and the frame. Here are the pics for reference. I'm curious what height you come up with on yours.
  #27 (permalink)
Old 06-24-2008, 02:13 PM
Almost the same...maybe 1\2-1\2" bigger....hard to take pics and hold the tape myself..lol
  #28 (permalink)
Old 06-24-2008, 02:22 PM
You could probably get away with the 9" block then, unless you wanted it a bit rear-high, then I'd go with the 10".
The only other thing I just thought of is that I have a 350 and yours is a 250. IF the rear springs are the same, and the only difference is the blocks, then its not an issue. If there is a difference in spring arch / height from the 250 to 350 then it's something to consider. I think it's just the factory block difference though.
  #29 (permalink)
Old 06-24-2008, 02:26 PM
I think the rear spring paks are the same...I have all the towing options that you can get for a 250...overloads, sway bar..etc...
Thanks for the pics and the help!
  #30 (permalink)
Old 06-24-2008, 03:16 PM
so did either of you take a stock measurment? how much lift do you have exactly? if you need one i can probably go grab one...
i know you both prob dont care...but i am of course interested since i want to lift mine like yesterday...haha
