Paint and rusting at bottom window corners - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-16-2013, 05:22 PM Thread Starter
I had a rust bubble at the bottom rear corner of my passenger side window that was re-painted under warranty.
I now have pretty bad rust on both my driver side doors in the same rear spot. I dremeled off the rust, primed, and hit it with the Motorcraft touch up paint myself since it was out of warranty, but it only came back worse.
I heard there were some issues with missing/improper steps in the paint process on some trucks and that Ford would cover it. I asked my dealer and they said they never anything like that. Either they were being honest or playing dumb I dont know.
Can anyone shed some light on this?
09 F350 SRW- H&S Mini Maxx with KEM 7 tune card, AFE 4" dpf/doc delete, AFE PG7 drop in soon to be S&B CAI, and some other exterior/interior work
06 F350 SRW- IDP Livewire tuned, studded, CAI, 4" DP to empty, Sinister EGR Delete, 6.4 Banjos & Blue spring, New: oem turbo, ficm, oil cooler etc...
02 2500HD- Hypertech programmed, true duals, AEM CAI
066.0 is offline
post #2 of 9 Old 02-22-2014, 08:31 AM
Bringing back on old post, but I'm having the same issue. Anyone done anything to correct this for good?
2008 Ford F-350 CC/LB 4X4
Hoosierdiesel is offline
post #3 of 9 Old 03-11-2014, 01:12 PM
cat10's Avatar
have the same thing going on just the drivers door tho
08 f350 diesel regular cab
fisher plow
Boston Hill fence 978 475 9300
cat10 is offline
post #4 of 9 Old 03-13-2014, 06:32 PM
Mines happening to. Also had a few big rock chips that came off to.
Trouble maker is offline
post #5 of 9 Old 03-23-2014, 12:51 PM
Sounds like a question no one has an answer to. I would also like to know what causes this.
mich800 is offline
post #6 of 9 Old 03-23-2014, 04:39 PM
09SDLariat's Avatar
Quoted: 10 Post(s)
Garage
I just posted a new thread about this yesterday. I'm going to talk to the body shop this week. It bs on a $60,000 truck after 4 years.
09SDLariat is offline
post #7 of 9 Old 03-27-2014, 02:22 PM
Mine has just over 42K... Issue is mainly on drivers side both doors only on the rear corner.
post #8 of 9 Old 03-28-2014, 09:54 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Its just the way the rocks and garbage splash up.in wintery areas that use salt especially the drivers side will usually get it worse because you have all the extra splash up from the oncoming lane.
I'm a big POR15 fan. When I painted my truck I used it as the primer for the rockers and everywhere there is rust. The Key to that is to topcoat it while its still tacky or nothing sticks right.
Por15 treats the rust you can't get with a grinder, and then locks it away better than any epoxy primer out there.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #9 of 9 Old 03-28-2014, 10:40 AM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Look in the fine print of your owner's manual, because there is FEDERAL LAW that extends warranty for corrosion protection and emission systems well beyond that crappy 36-month-36k mile crap. Ford paid a local auto paint and body company to repaint ALL of my agency's 2008 through 2010 Crown Vics on the hood, top, and trunk because of peeling paint that was beginning to lead to rust issues. There may be a TSB (technical service bulletin) or recall out there that smaller dealerships may not be aware of or want to fool with, but an Oasis report would definitely list it.
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
