service powerscope mirrors - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-16-2013, 02:13 PM Thread Starter
I have an '08 with the heated power-scope side view mirrors.
The drivers side mirror doesn't like to retract all the way, and sometimes when I use the power button to extend it into tow mode, it sticks and I have to put some outward pressure on it while hitting the button to get it to go.
Are there any instructions on how to disassemble the mirror to try and figure out whats causing it to stick?
I tried lubricating it with no luck.
Thanks
2008 F250 CC 4X4
Job I 6.4L
King Ranch
jbiersba is offline
post #2 of 5 Old 08-16-2013, 04:48 PM
F250Marine's Avatar
Use the search function there is an awesome write up on how to fix these mirrors.
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
post #3 of 5 Old 08-17-2013, 09:00 AM Thread Starter
What would I suggest I search on? I've looked around and saw your posts on separating the two halves of the mirror body prior to posting. Maybe i'm missing something, but i'm looking for some guidance on servicing the extension arms??
Thanks
2008 F250 CC 4X4
Job I 6.4L
King Ranch
jbiersba is offline
post #4 of 5 Old 08-17-2013, 09:15 AM
F250Marine's Avatar
Here is the link to the thread Power Fold Fix for $5. It will at least help you get them apart, I bet the gears are bad on the extenders should be able to fix them the same way. Hope it helps you out these mirrors aren't cheep.
post #5 of 5 Old 08-17-2013, 09:38 AM Thread Starter
thanks that helps!
2008 F250 CC 4X4
Job I 6.4L
King Ranch
jbiersba is offline
