OEM Grill Disassemble and paint - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-25-2013, 05:16 AM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
Does anyone have a write up on how to remove the front grill an dpull all the inserts out without damaging the clips. See my grill in sig it has all the tan inserts and I want to remove it and scuff up the chrome and paint it white to match the truck then put the tan inserts back in. Has anyone done this on a white/tan King Ranch? I would like to see what it looks like.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 3 Old 07-26-2013, 06:45 AM
SpDyDaVe's Avatar
Honestly it's very easy to take the grill off our trucks.
A quick trick to avoid scratching the paint on your truck it to put a strip of painters tape between the upper portion of the grill and the hood.
There are a couple of bolts on the bottom and screws at the top. Once they have been removed pull towards you from the bottom and push up (painters tape , from there on the top there are a few clips that will pop off easily. It should take you less than 15 minutes.
From here you'll see the pop tabs on the back side to pull apart the rest of the grille. Good luck with your project.
2008 F250 CCSB Lariat
Spartan 350, Extreme Studs, Elite Lifters, Smith Bros Pushrods, RCD (Oil Pan, Manifold, Up pipes w/EGR), 6.0 Manifolds, S&B CAI, 4" SS DP, 5" SS Exhaust, Sinister Coolant Filter, Mishimoto Intercooler & Rad, K&P Oil Filter, OUO (ALA'S, Traction Blocks, Short Gusset Bars, Pin Kit, Top Plate, Track Bar), ICON (2.0 Front, Rear, Dual Steering, Springs, TEI)
NRA Life Member
SpDyDaVe is offline
post #3 of 3 Old 07-26-2013, 07:47 AM Thread Starter
Quoted: 14 Post(s)
Ok cool, so the tan inserts will pop out the back pretty easily? Now I would like to see a pic of a white grill with the tan inserts
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
