2010 f350 drw to srw - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-14-2013, 04:53 PM Thread Starter
Please don't tell me to just buy a srw or to keep it as is. I would like to know if anyone can tell me if there is a wheel combination using back spacing in order to just get rims and tires and remove the fender flair. In my case I'm just getting a srw bed since I currently have a service utility body.
Thank you
Narcco is offline
post #2 of 7 Old 07-14-2013, 07:31 PM
I've always wanted to know what stock srw wheel look like on drw axles with a srw bed. I'd try that first on front and take pics. But the front spacer is removeable to make it a srw axle. I think you will have to get new studs or use the ones out of the spacer. one the rear you just have to swap axle with same ratio.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #3 of 7 Old 07-14-2013, 08:32 PM Thread Starter
I was really hoping I didn't have to swap axels guess I'll look into it am see what it will run me.
Narcco is offline
post #4 of 7 Old 07-22-2013, 10:57 PM Thread Starter
I would prefer to do a set up similar to the one in this thread Dually to Single Wheel Conversion- What is needed? - Dodge Cummins Diesel Forum
Just don't know the right set up for a ford.
Narcco is offline
post #5 of 7 Old 07-22-2013, 11:54 PM
BIG Laing's Avatar
It is possible. Rickson Wheel Manufacturing
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 7 Old 07-23-2013, 12:02 AM
BIG Laing's Avatar
I am glad you have srw bed, so it doesn't look like this Dumbest pics..whatcha...
post #7 of 7 Old 07-23-2013, 04:48 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Lol, that's just hideous!!!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
