Template for Bed Divider?? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-19-2013, 05:13 PM Thread Starter
Anyone know where I can find a template to use when cutting custom bed dividers?
In the past I've used 2X6s cut to length, and then just put a 45degree bevel on the bottom. This works OK, but using the 45degree bevel really removed a lot of material, and on a few of the slots in the bed, I don't believe the side wall is 90degrees. The end result is usually a loose fitting bed divider.
I'd like to make some nicer ones, and possibly have them coated with a bed liner to ruggedize them. Figured if someone already had templates i'd love to use them. Otherwise, I guess i'll have to get some cardboard and use a little trial and error to get a better fit.
Thanks
2008 F250 CC 4X4
Job I 6.4L
King Ranch
jbiersba is offline
