Lights in Road Armor Bumper - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-15-2013, 10:39 AM Thread Starter
Just recently added a road armor stealth winch bumper to my truck. It has a spot for 4 of the PIAA lights in it, but im really wanting to go with led lights possibly something like rigid industry lights.
Has anyone added lights to their bumpers? I just don't want it to look funny having a square light in a round hole. So any input would be great. Thanks.
wwillmon is offline
post #2 of 12 Old 06-15-2013, 10:53 AM
Term3's Avatar
Quoted: 2 Post(s)
Only dummies put square pegs in round holes. LOL
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 12 Old 06-15-2013, 01:27 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
Buy a round LED light. Vision X makes them and they're brighter than Rigid's and have a lifetime warranty.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 12 Old 06-15-2013, 04:01 PM
Snake's Avatar
Quoted: 47 Post(s)
Square lights, round hole. Yeah, you'd look like the kindergarten flunky.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 12 Old 06-15-2013, 09:08 PM Thread Starter
actually i saw some d2's in a road armor bumper that had the round holes and it didnt look bad. Thanks though.
But ill check out Vision X thanks for the recommendation.
wwillmon is offline
post #6 of 12 Old 06-19-2013, 04:48 AM
stinkbug's Avatar
How bout both? There are round led lights that throw as much light as rigid!
stinkbug is offline
post #7 of 12 Old 06-19-2013, 07:48 AM Thread Starter
Yeah I'm really liking the light cannon from vision x but it's a 4.5" light, I just need to see if a 4.5" light can be squeezed in there or if I only have exactly 4" to fit a light. It seems like they only make either a 3.5",4.5, or 6" or bigger round led. So I may have to end up going with a 3.5".
I really appreciate the help though everyone!
wwillmon is offline
post #8 of 12 Old 06-19-2013, 09:27 AM
Term3's Avatar
Quoted: 2 Post(s)
It won't fit right inside the hole but I am assuming your bumper has a short pipe hole for the lights like mine does so just mount it so that the light is right up against the end of the pipe. The light is 4.72” wide to the OUTSIDE edges and the frame around the lense is probably at least a 1/2" wide so my calculation is that the lense would not be covered up at all even if it was in a 3.72" hole. My bumper lights I left about 1/8" back of the pipe hole so that snow and what-not could still get around the light and not fill up the pipe against the light.
Term3 is offline
post #9 of 12 Old 06-19-2013, 10:06 AM
Quoted: 20 Post(s)
Look into the Solstice series from Vision X. They offer a 4" round in that particular model. I have the Solstice Prime 4" squares in my factory fog light location and those suckers are bright. If you want something cheap and bright, they're utility series has some 4" rounds that are nice and are offered in a 3 watt LED or a 5 watt LED. I was looking at getting some of those mounted for some auxiliary lighting on my truck. If you call Vision X, you might be able to get something custom made, like a 4" round housing with 10 watt LEDs in it. They've done custom work for me in the past including dual beams and custom optics.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #10 of 12 Old 06-19-2013, 12:40 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Pic of mine with round lights, works good
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
