need more lift - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-07-2013, 09:44 PM Thread Starter
powerstroke4ever's Avatar
need more lift
Hello guys, I recently bought some new wheels for my truck and now it rubs pretty bad when i turn into drive ways or hit bumps when I turn. My truck has a 8" pro comp lift with 20x12 fuel hostage rims (38x15.5R20 toyo mts).The question I have is is it possible to increase the size of my lift by like 2"+ to clear the front tires, without doing a body lift. I have trimmed up the fenders a little bit, but would like to Not to hack up my whole truck. So if there is a way to do it what would be required? Suspensions shops around here just try to sell me a whole new lift and arn't of any help, so thats why im posting here. Thanks in advance for any information/ suggestions.
2008 Harley f350 ccsb, 8.5'' lift, 38''x15.5r20 toyo mts, afe 4'' turbo back, afe cia stg2 tuning via spartan tunes
powerstroke4ever is offline
post #2 of 5 Old 06-08-2013, 02:48 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Couldnt you add a spacer up front and an add a leaf in the rear or bags
Big_Smokey is offline
post #3 of 5 Old 06-09-2013, 11:57 AM Thread Starter
yeah i was thinking of a spring spacer or leveling kit but all the suspensions shops refused to sell me one and said it was a bad idea that the lift was designed to be a certain height and messing or adjusting the lift would make it unsafe and just lead to problems. So thats why i was wondering if someone has done something similar and how it worked out for them?
post #4 of 5 Old 06-09-2013, 03:02 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
I think they are full of poop. Its no different then adding a leveling kit to a non leveled truck...
post #5 of 5 Old 06-10-2013, 10:38 PM Thread Starter
So adding a coil spacer or leveling kit i should be fine, would it affect my drive shaft angle since its already lifted? or would i have to get a different trac bar or brake lines for the front? Sorry about all the questions just trying to figure out if it will work before i go and order stuff. Thanks
