running board help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 02:11 PM Thread Starter
running board help
i have a 2008 f250 with chrome running boards. i have them off my truck because, i was going to paint them black to match my truck. the bolts that hold the mounts to the running board wont come out. is there something i am missing? any info on removing the plastic peaces would be great to!
6.4l Hansen is offline
post #2 of 8 Old 05-23-2013, 03:43 PM Thread Starter
I searched and can't find info. Somebody on here should know
post #3 of 8 Old 05-23-2013, 06:41 PM
Quoted: 2 Post(s)
there are little nuts inside the running boards. if the bolts get over torqued, you can spin them off and then the bolt and nut will just keep spinning. i bought a set of used running boards for my KR and got rid of the plastic ones. when i was installing my "used" boards, i overtightened two of the bolts... i learned the hard way. not sure of a way to get the old bolts out other than grinding them out.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #4 of 8 Old 05-23-2013, 07:54 PM Thread Starter
Okay thank you. But if you grind them there would be no way of putting new bolts on.
post #5 of 8 Old 05-24-2013, 08:28 AM
Quoted: 2 Post(s)
correct.. its a loose loose situation.
Kris
post #6 of 8 Old 05-24-2013, 08:47 AM Thread Starter
Okay. Looks like I well try to just paint around it then. Thanks for the info
post #7 of 8 Old 06-14-2013, 08:29 AM
Lunchbox21984's Avatar
how much do a set of factory boards normally run? i have aftermarket ones and not impressed by them at all.
good luck OP on getting them painted.
2008 F250 6.4Ltr, 4X2, Crewcab w/ Shortbox
Lunchbox21984 is offline
post #8 of 8 Old 06-14-2013, 09:37 AM
Quoted: 2 Post(s)
i found a used set of OEM boards on ebay for $200. shown on my truck below in my sig.
Kris
