Different kind of exhaust tips - Ford Powerstroke Diesel Forum
post #1 of 29 Old 05-16-2013, 08:42 PM Thread Starter
Hennessy05's Avatar
So I've been toying with the idea of getting my exhaust redone. Just hopng to get some feedback or maybe some different ideas. Everyone has seen 1/2 ton gassers running around their local towns with the 45 degree mitre cut exhaust tips on the rear. I love that look, so what I was thinking of doing is getting dual 6 inch mitre cut stack tips and getting a muffler shop to weld em up underneath my truck at 45 degrees out behind the rear tires. Anyone else think that'd look good?
Just for reference. I currently am running the Diamond Eye 5 inch turbo back straight pipe
'08 F250 6.4
-S&B
-H&S
-Diamond Eye
-Fabtech
-XD Series
-Toyo
-Amp Research
Hennessy05 is offline
post #2 of 29 Old 05-17-2013, 05:10 PM
IMO diesels look best with hidden exhausts. I like your idea of the 45• but hidden over the rear axle I think would look good. I have a single over the rear axle pointing down and like it a lot. I would like someday to get my tips dual and chrome, I'll see if I can find a pic
rdwngs444 is offline
post #3 of 29 Old 05-17-2013, 05:28 PM
post #4 of 29 Old 05-17-2013, 06:34 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
I like the dual exit behind the rear wheels. thats what i was going to do, but just did asingle. thats been played alot though. its just what i prefer
Big_Smokey is offline
post #5 of 29 Old 05-17-2013, 06:37 PM
Korx's Avatar
Might be a dumb question.. But what is the point of wasting money on tips if you're dumping it above the rear axle where you won't see it? Much less the point of dual dumps?
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #6 of 29 Old 05-17-2013, 07:29 PM
44magnum's Avatar
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #7 of 29 Old 05-18-2013, 05:58 AM
theplumbingmedic's Avatar
That tip looks wacky
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #8 of 29 Old 05-18-2013, 06:11 AM
Njstroker91's Avatar
Ar15 tip?
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #9 of 29 Old 05-18-2013, 06:25 AM
sargar's Avatar
This question is for the guys that dump over the axle/under the bed. How is the sound difference as far as resonance, drone, etc? Second question is about smell. I love the smell of diesel but I have been told that dumping over the axle allows a nasty, oily smell (not a diesel exhaust smell) to develop under the bed that you notice even when the engine is not running. Any truth to the second one?
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #10 of 29 Old 05-18-2013, 06:41 AM
IMO, it's a cleaner look without seeing the exhaust, and that photo isn't my truck but its probably lifted so you can see the tips if you look. Also, it hides that obvious aftermarket huge exhaust tips from the cops.
