tires and wheels - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-08-2013, 02:24 PM Thread Starter
tires and wheels
Hey guys im going to be upgrading my tires and wheels on my 08 f-350.. its stock height, I was wondering if I could fit a 35" either going with nitto trails or wranglers.. anyway im thinking about the moto metal m0961 wheels in a 20" so I know the 20x9" offset is -24mm and backspacing is 4.56" and the 20x10 is +18mm with backspacing of 5.71" im not sure what the offset or backspacing is on the stock 18" has anyone ran this set up? with the 35s rub with the set up? or will I have to go to a smaller tire?
meilleur17 is offline
post #2 of 8 Old 05-08-2013, 05:37 PM
BIG Laing's Avatar
Stock offset is +40 on a 8" wide wheel. Those 9" -24mm offset wheels will NOT work.
The 10" wide +18mm will rub the radius arm near full lock with 12.5" wide tires. I think you would want a leveling kit to run them anyways (although they will still rub the radius arm)
35x12.5 works great on stock 08+ fords on a 9" wheel with an offset between +25 and +12.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 8 Old 05-10-2013, 09:57 PM
Nitto Trail Grappler 295-65-20 (also marked 35-12-20) on Stock King Ranch 20's
Slight rub on the liner when full lock to the left, nothing to the right.
If I pull the liner away a little, it will be fine, I'm going to fab up something....
2008 F350, stock height, no lift in front.
S1nned is offline
post #4 of 8 Old 05-11-2013, 06:39 PM
Quoted: 47 Post(s)
As in my sig...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #5 of 8 Old 05-13-2013, 06:52 AM Thread Starter
Thanks guys, I went ahead and installed a level.. And going to be installing 35x12.5x20 nitto trails on xd810 wheels!
post #6 of 8 Old 05-20-2013, 10:37 PM
tony97gt's Avatar
Pics! I'm also in the market for rims/tires. Looking at the Toyo OC MT 35x12.5r20/10 at $323 each installed. Not sure on the rims yet but after seeing a few trucks on here I'm thinking they will be -12 offset for sure.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #7 of 8 Old 05-21-2013, 01:51 AM
BIG Laing's Avatar
You do know the backspacing changes from 8, 9, and 10" wide rims with the same offset right?
What I am saying is a 9" wide rim with a 0 offset has the same backspacing of a 10" wide rim with a -12 offset...
post #8 of 8 Old 05-21-2013, 01:55 AM
tony97gt's Avatar
No I don't know a whole lot about that stuff. Thx for the heads up though.
tony97gt is offline
