Stupid Question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-22-2013, 03:28 PM Thread Starter
Stupid Question
I have 20" ATX rims with the 37" toyo tires on them. Noticed one tire was a little low. Found it had a valve stem that was leaking. Question is what size valve stem do I need to get and can I replace it without taking the tire off? One last thing, I was reading that there are high pressure valve stems that are part metal, but mine are completely rubber. Is that maybe why they failed early?
Thanks,
David
2005 6.0L F250
EGR Deleted
merkfalc is offline
post #2 of 4 Old 04-23-2013, 06:21 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
I would take it to a tire store. Happened to me and they fixed it in 2 secs.
Sent from AutoGuide.com App
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #3 of 4 Old 04-23-2013, 10:23 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Valve stems are installed from the inside of the wheel so you can't replace them with the tire on.
If it is just leaking from the center of the valve stem and not the actual rubber itself, then you can just remove the valve out of the stem and replace that in 30 seconds!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 4 Old 04-26-2013, 05:56 AM Thread Starter
Thanks for the replies. Honestly I had no idea you could replace the innards of those things. I'm going to pick up the tool and a few of the cores for the next time it happens.
David
2005 6.0L F250
EGR Deleted
merkfalc is offline
