Fender flares wrecking paint - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-02-2013, 05:21 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
My rear fender flares have rubbed off the paint underneath and in some spots it's showing maybe at most a 1/4 of an inch outside the fender flare. I was thinking about tracing where the fender flare sits and color match bed liner and have it sprayed so it just barley sticks out further that way it stops this from happening. Any one have a better idea?
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 7 Old 04-02-2013, 06:11 PM
montana6.0's Avatar
Yeah it sucks mines the same way.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #3 of 7 Old 04-04-2013, 01:11 PM
slowcoupe's Avatar
Quoted: 11 Post(s)
3M clear bra tape or some sort of a matched vinyl would do the trick for ya.
2000 Regular Cab SHORTY truck.
-7.3/ZF6 combo.
-TS tuned
-5" exhaust to 7" single mitre.
-DJM 3/5 drop
-22" wheels wrapped in 305 nitto 420's
COMING SOON
-Midwest shifter
-DP tuner
-2008 F350 CCLB ZF6 truck. Leveled, 22's w/37s, deleted, H&Stuned etc -SOLD
-2005 F350 CCLB 6" 37's, studded, tuned etc-SOLD
-2002 F350 CCLB 6"lift, 20's w/35's, DP tuner etc -SOLD
-2005 F250 CCLB 8", 20's w/37's bunch of mods -SOLD
-2002 F250 CCSB 4" lift,18's w/35's DP tunes etc -SOLD
slowcoupe is offline
post #4 of 7 Old 04-04-2013, 01:21 PM
44magnum's Avatar
Quoted: 2 Post(s)
What fender flares are you guys running? Isn't there a gasket/seal between the flare and the fender?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #5 of 7 Old 04-04-2013, 01:23 PM
slowcoupe's Avatar
Quoted: 11 Post(s)
Bushwackers I had on my last truck did rub the paint. They do have a rubber strip but dirt gets in between there and begins to rub. This happened during previous ownership but every time I washed the truck I'd pull the flare away a bit and spray out and dust particle that was in there.
-7.3/ZF6 combo.
-TS tuned
-DJM 3/5 drop
COMING SOON
-Midwest shifter
-DP tuner
post #6 of 7 Old 04-05-2013, 09:37 AM
layson's Avatar
Quoted: 82 Post(s)
Had the same thing happen to mine. I ended up getting some whelting? I can't remember if that is correct name, but it is a piece of rubber that fits over the edge of the flare. It definitely helped but the damage is already done.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 7 Old 04-05-2013, 12:28 PM
have had the same issue on my last 2 trucks. its not as bad on my current truck because i was cheap and bought the knock off bush wackers. the rubber is round and not flat so it doesn't trap as much crap. to late now so i would pro line x it, but on my next truck i will use the 3m clear stuff before i put the wackers on.
tbeaton is offline
