How easily should the slip-joint, slip? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-23-2013, 06:29 PM Thread Starter
44magnum's Avatar
Ok so I was installing my lift blocks today and shoved the axle too far back to get it out of the way and my drive-shaft fell apart at the slip joint. (2 piece drive-shaft) So I went to put it back together and its going to take a hammer and a wood block to get it back together, its splined but is there only one way in which it will go back together? Or are all the splines the same?
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #2 of 8 Old 03-23-2013, 07:19 PM
whats is ur question is there a issue reinstalling the d/s spline into trans output??
the splines should be all same there is no (keyway or oversized natch)
it should go in with min. force clean and lube before reinstalling
nj powerstroke is offline
post #3 of 8 Old 03-23-2013, 07:35 PM Thread Starter
44magnum's Avatar
Ya I was wondering if there was a keyway or something of that sort. I am having trouble getting it back together easily and didn't want to mess up anything by hammering it. Right now I have it on about 1/3 way but I can't push it together or pull it apart by hand.
And the slip joint I'm referring to is just after the carrier bearing, towards the rear diff. (2 piece drive shaft) But it functions the same way a normal slip joint into the transmission/transfer case, would.
44magnum is offline
post #4 of 8 Old 03-24-2013, 02:24 PM Thread Starter
44magnum's Avatar
Took it off today and got it out in the sun where I could look at it. There is key-way of sorts, one oversized spline & groove. Lined up correctly, lubed it up well and put it back on.
44magnum is offline
post #5 of 8 Old 03-25-2013, 03:28 AM
i have read about there not being a key of sorts as well. I wonder what trucks they are driving. I have just recently greased both slip joints and they both had a locator spline.
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #6 of 8 Old 04-20-2013, 10:38 AM
What do you use for the sleeve clamps, or were you able to reuse them?
PerilousLiberty is offline
post #7 of 8 Old 04-20-2013, 11:14 AM Thread Starter
44magnum's Avatar
I used a big zip tie and got it really tight.
44magnum is offline
post #8 of 8 Old 04-22-2013, 03:41 AM
i was able to re-use them. I used a skinny flat screw driver to spread the clamp to allow the boot to be slipped back on the shaft and then to get the clamp tight again i used a pair of side cuts. I also tried a hammer hitting a flat screw driver with another flat screw driver on the other side propped up against the nearest object to hold it in place while hitting the first screw driver. Confusing i know but not sure how to explain it otherwise...
Try the side cut method and then i used black silicone around the boot ends to keep dirt and moisture out.
