leds - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-11-2013, 07:10 PM Thread Starter
zdawg8394's Avatar
leds
could someone inform me on the bulbs they have used in the lisence plate lights, cargo lights and reverse light? trying to convert to led.
zdawg8394 is offline
post #2 of 7 Old 03-11-2013, 07:25 PM
Wannabitawerm's Avatar
leds
I use replacement LEDs that are listed under the same bulb numbers as the incandescent. 3157 for brake and turn, 3156 for reverse, 1194 for interior and runnin.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 7 Old 03-11-2013, 07:34 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Reverse lights are a 921 bulb. To be honest I have tried two different sets in the reverse bulbs and they look cool but less light gets to the ground. The design with the reverse up so high doesn't work well with the LED's. for cargo lights I believe they are called a t10 wedge style. I have everything but my turn signals and tailights led.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #4 of 7 Old 03-11-2013, 10:40 PM
leds
I have zero incandescent on my truck. LEDs and HID's all around.
post #5 of 7 Old 03-12-2013, 05:56 AM Thread Starter
zdawg8394's Avatar
just ordered my hids, had 8k on my last vehicle but went with 6k this time for more light. thinking about ordering leds soon, i saw some leds that look really promising for the reverse lights but there 40 dollars a set. and i plan on doing switchbacks in my front turn signals but ill have to get to the dealer to get plugged into the IDS so they can turn off the fast flash if im correct.
post #6 of 7 Old 03-12-2013, 06:01 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
What are switchbacks?
And iirc, retrosolutions (site sponsor) has a bright back up light that are 20.00 each or something....I don't know if they will help on these trucks because of them having the reverse lights up so high. A lot of people add a set of fog lights to the back of the truck. They help a ton....or you could run a high wattage LED light bar from recon or the like. They put out a TON of light and are slim mounted and use a small footprint.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 7 Old 03-12-2013, 06:37 AM Thread Starter
zdawg8394's Avatar
switch backs mean there are two colors in one bulb. so in my front parking lights i will have white when the running lights/parking/headights are on and when i hit the turn signal they will turn amber. they come in ao( amber off) or aw (amber white) AO means that only the amber flashes while in turn signal mode and AW mean they alternate amber-white-amber-white on flash mode. i like the AO's better they look more factory.
