Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 01-05-2008, 11:41 PM
lunchboxrts lunchboxrts is offline
LED bed lights
Just finished up installing LED's in the bed of my truck. Makes it real nice at night hooking up the goose neck or trying to find things. The pics are not the greatest, the lights are much brighter in person but you get idea. Let me know what you guys think.
Old 01-05-2008, 11:43 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
looks good... where exactly did you hook them up?
Old 01-05-2008, 11:49 PM
For now I am pulling power directly from the battery with a switch mounted in the bed until I can figure out how to make my upfitter switches hot when the keys off. The LED's are clusters of 8 super brights mounted on a aluminum tab which I then mounted to a strip of aluminum flat stock. I then screwed them to the slant under the bed rails. I used a total of 10 clusters five on each side.
Old 01-06-2008, 08:23 AM
CamTom12 CamTom12 is offline
Send a message via AIM to CamTom12
Looks good!
Old 01-07-2008, 10:18 PM
Here is the place i got the LED's. The nice thing is they are already setup for 12 volts.
eBay Store - Sure Electronics: LEDs: 100 pcs 3mm Red LED 1200mcd Free Resistor
Old 01-08-2008, 07:04 AM
AJF AJF is offline
Looks good man...gotta do whatever it takes when hooking up at night
Old 01-08-2008, 07:13 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
Looks good...
Old 01-08-2008, 07:29 AM
mbixler mbixler is offline
Let me know if you can hook it up to an upfitter switch. That would be awesome! I think I am going to get the recon ones...
Old 01-08-2008, 11:30 PM
SMOKE ROLLER
You can hook whatever you want to the upfitter switches. I have switch 1 for my Snow kit, switch 3 for my front strobes, & switch 4 for my rear strobes... Make it happen you'll love the convience and clean look...
Old 01-09-2008, 05:45 PM
I thought like the first two switches were for so much power and the last two were also. How do you get to the wires to hook them up?
