| 6.4 Exterior Discussion Body and Accessories Talk |
Headlight tint
Can u smoke out just the turn signal lense in the headlight. I think I saw one done the other day any info?
Sent from my iPhone using AutoGuide.com App |
Yes....but you have to take the lights apart to do it.
Look at this post - Scroll down to post#12 (# is on the right side of the blue bar above each post) Painting Headlights Once apart, you can paint what you want. For smoking, some people use stuff called "Night Shades" |
I just took my headlights apart not too long ago to do a projector retrofit. Took the orange/yellow reflector out (3 screws and it comes out) and painted it about 3 times with black paint. no more orange!
its a pretty easy job, just a pain to separate the front lens from the housing. The rest is cake.
If you're going to open up your headlight housing, you might as well do a projector retrofit while its open. I'll try to get you a pic tomorrow. You should look at buying some butyl to use when you reseal the housing.
For all other tinting I use a model paint called Tamiya which can be found at most model stores, ebay, or amazon and the color is smoke. It's a heck of an expensive little can of spray paint but worth it to do it right in my opinion. Here's a link to what I'm talking about: I tinted my amber reflector in my headlights with it and it worked great. |
This is only a rough install, I'm not done with it yet but here's an idea of the smoked yellow lens. Headlight was put into the oven and taken apart. I used oven cleaner to remove the chrome paint off the reflector bowls. Behind that was beautiful BLACK plastic. [IMG]
[/IMG]
