| 6.4 Exterior Discussion Body and Accessories Talk |
I have an '08 F250, 6.4L crew cab, short box, 4x4. With a 6" lift, riding on 37x13.5x20" Toyo Mt's.
So I'm suffering the usual set backs of adding big tires and a lift. I'd like to know what gears anyone switched to after doing these mods, and what results you've gotten from the change. I don't do extreme towing or excessive work with my truck, its just general pick up truck use. I plan on adding an intake, exhaust, intercooler,and chip soon to also aid in the power and fuel economy loses. Which brings me to my next question, has anyone done brake kit upgrades etc? and has anyone switched to discs in the rear? Any proper answers, or direction to other discussions on these topics (saving me loads of surfing time! there's sooo much info on here!), would be greatly appreciated! THANKS! Last edited by DieselPowerFan; 12-12-2012 at 10:12 PM. |
What gears are in your truck already? 3.55? 3.73? You should be fine with 3.73, 4.10 might suit your needs better though. As for brakes, these trucks already have disc brakes on all 4 corners. I havent read of to many people upgrading the whole brake system. A good set of pads on stock rotors will work just fine. My truck stops well with stock pads and rotors, but Im only on 35's.
Some people do a brake upgrade. If you have the extra money it for sure wouldnt hurt anything. If you dont want to spend the money you will be ok. I havent read up too much on the gears for these trucks. i came from f150s soi know on those trucks 4:56 or 4:88s was what was recommended for 37" tires. They also dont have the power of these trucks.
Id spend my money on a good tuner. dpf delete EGR delete and intake. then do the other stuff later |
Thanks for the responses!
The brakes are going to be a must for me, as breaking distance is absolutely scary, the feeling is so soft and the truck takes its sweet time to come to a stop. As for the dpf and egr delete etc, I will be addressing all these and the other common issues with the 6.4L trucks very soon. I'm just currently planning on which parts to pair together etc. I also want to upgrade the lift that was put in it, the ride isn't the greatest, I realize it's a truck and yes its lifted, but I've been in trucks with a high end Fab Tech or Pro Comp lift, and mine doesn't compare with the cheap Tough Country lift that is currently in it, dual stabilizers are a must to, as the truck loves to wonder big time after hitting a large bump or whoop at hwy speeds. |
I did not do breaks yet either but if you hot rod around at all you would be silly not to as the truck is way to big and fast for the stock system. I will add breaks and I dont even hot rod around. for around 4K you can get 16" rotor wilwoods 6 piston that would do the trick no problem but I relize 4K is alot so you could also go with BEAR or SSBC for alot less in 14" rotors. my eslade has SSBC on it and I am gonna see it they will mount to my truck and get wilwood for the esclade (mostly for looks the SSBC stop it no problem even supercharged) |
My breaking issues described are from just day to day NORMAL driving through town and country Hwy's. I don't "hot rod around", as stated I have no faith in the performance of the stock breaks, and with the lack of steering stabilizers at the moment, I keep my driving habits casual. I just bought the truck (said good bye to my 2011 in the divorce blah blah blah) so I'm sorting out all the mechanical and other typical gremlins associated with the stock and aftermarket parts.
Thanks for the responses and suggestions. |
same here i have no issue stopping, have the brake system checked.
I know people say go 4.30 gears but idk, when i move up to 37's ill probably go to 4.10. i have 3.73 on 35" tires right now. |
I have the same lift with 38" tires. I will be going to 40" tires very soon. I would like to know what is a good size gear to run to try and bring it back to stock. Not sure on a 4.30 or 4.56 and a good brand. Any help would be great. Thanks
