17s and 35ish tires - Ford Powerstroke Diesel Forum
Old 11-28-2012, 05:03 PM
17s and 35ish tires
Anyone running close to a 35 or a 35 on 17" Wheels at stock height? I dont want to go up to a 20... It will be for my 09 below....
Old 11-29-2012, 04:29 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
assuming the 17's are as wide as the 18 and 20" stock wheels they will fit no problem.
Old 11-29-2012, 06:12 PM
Blackcloud....How wide can I go with on the 35s with the 17s? How wide is the 18 & 20s. I am going after market wheels..
Old 11-30-2012, 03:46 AM
a 35x12.5 will be the max tire that you would want to run on an 8" wide rim. Even then the ideal rim is a 9". They will fit on 8" but they may bulge a bit in the center if you run max psi in the tires. I believe stock 18's and 20's are all 8" wide, I dont know about the 17's. It will say inside your door how wide they are.
Old 11-30-2012, 07:02 AM
Ok, I figured out the combo.....
35x12.50x17 riding on 17x8 XD series spy's chrome...
Old 12-04-2012, 05:05 PM
35's will fit on an 8" wide wheel.
