| 6.4 Exterior Discussion Body and Accessories Talk |
I'm looking at some 20x9 wheels and want to run stock height for now. I will eventually level out but just not right now. The wheels are 5"Backspace with 1 offset and 5.75 Backspace with 20 offset. Which one should I get? Tires will be 35x12.5
Can't say for sure. My plan is to install the front tires and check for issues. If I need a lift, I'll put the stockers on and drive down the road to 4 Wheel Parts and get that taken care of. If not, then so be it.
I ordered 20x10, -12 offset. This website might be helpful. Custom rims, wheel tire packages for your ride - RIMSnTIRES.com |
Still waiting patiently.
Slight change of plans. Decided to get the Pro Comp Nitro 2.5" kit (the 3.5" kit was the wrong part #) and that will be installed next week. I'll install the wheels and tires whenever they come in...
I have a procomp 6 lift but changed out the shocks..procomp shocks are not the greatest and seals leak..but they do have a life time warranty..I run 37 x 13.5 Toyo MT's with a 11" wide wheel with -24 off set..no rubbing inner or outer...on the street. I know it will rub the fenders while turning in a off road condition..hasn't happend but I know it will. Good Luck
Got the lift installed today... Pro Comp Nitro 2.5"
![]() ![]() ![]() SHOCK RELOCATION BRACKET ![]() COIL SPACER ![]() REAR LIFT BLOCK
Now I'm going to install some lights in my grille guard... Wheels and tires will be here Friday.
Rigid Industries Dually LED Flood Lights
Looks good! Maybe put 2 of those in the rear to help reverse!
