| 6.4 Exterior Discussion Body and Accessories Talk |
Looking good!
The issue is when you do the negative offset, it makes it rub worse. With a 2.5" leveling kit and -12 offset with 35" tires you should be able to get away with it. You will prolly have to zip tie the plastic inner fender back a little bit. But other than that you should be fine.
I need some help. i don't understand the whole offset deal. whats the minimum i need to run the american force justice ss 20x12 -40 offset with 33x12.5
thats a really wide wheel on a little tire. what are you plans for this cause i dont see a lift in your sig and with these wheels you would have to have a lift
really dont want a lift bigger than a 4.5 inch i pull a 36' fifth wheel and was wantin to know what i could by with
with a 4.5 inch lift you could run 37s but i dont think you could with a 12 inch wide wheel and a -40 off set that will be sticking out pretty far. if i were you id go with like a 20x10 with a -20 off set or something in that range. a 20x12 could work but you would need a positive off set probably.
So if I run the 20x10 -25 offset with a 35x1250 and a 2.5 or 3.5 leveling kit I'd be ok
yep you would be fine
Thanks man
Decided to go with the Fuel Hostage 20x10 (Stealth Black) and 35x12.50 Toyo OC MT. Should be here in a week or 2.
