| 6.4 Exterior Discussion Body and Accessories Talk |
Lift conversion from 8 to 10 help
I want to change over my lift from an 8 to a 10 set up. It is Fabtech # K2124. Ive crossed over the parts from what I have and the new rear kit. The items below are the only ones I need. Does anyone know how I can order them? I found the leaf pack and blocks. I cant locate the carrier spacer or U-bolts.
Items needed from Fabtech to change over rear 8 lift to a 10. FT20073 - Carrier Bearing Spacer FT744U - U-Bolts FTBK2 - 2" Block FTS42000 - Rear Leaf Pack As for the front I would like to add the 10" multiple front shock system # K2077DB and see if I can add a 2 added leveling kit spacer so that I dont have to change anything else. I dont know if this is possible. Please advise. |
Was wondering this also , I just want to make sure their are no driveline issues? , the carrier bearing spacer you found for the 10" is it larger then the carrier bearing spacer from the 8" kit ? or is there an additional spacer to lower it down more
It is a new 2" spacer that lowers the mounting bracket and then you use the old same shims.
Being I already have the add a leaf and 5 rear blocks could I just have a coupe new 6-7 blocks made and find some new 22-24 U-bolts for the rear?
