2.5" leveling kit questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-01-2012, 08:41 AM Thread Starter
lots of questions about lifting my 2009 f250 crew cab...... I've read good things about this ready lift
Ford F250 Super Duty SST Hybrid Lift Kit: 2008-2010, 4WD Only - 2.5"/2.0"R
and that would come with 5" rear blocks for the rear to level my entire truck out but it still uses the factory shocks...... 575$$$
also i called a local off road shop and can get a pro comp 2.5" kit which does front and back lift plus new shocks for the front for 800$$$ installed
my question is which lift to go with the thought of newer shocks and everything installed for a couple hundred bucks more sounds good to me.
also do i need an adjustable trac bar with this lift as neither of the lifts come with them? plan on running 37" tires with this lift.
any other routes or recommendations as far as lift suggestions or links to find a better lift on ebay would be helpful. trying to do the lift on a budget if possible
ess3489 is offline
post #2 of 9 Old 08-01-2012, 09:17 AM Thread Starter
moved to 6.4 section
ess3489 is offline
post #3 of 9 Old 08-07-2012, 05:46 AM
DSTRBD's Avatar
ReadyLift makes a decent setup, but if you want better performance and more wheel travel, I highly suggest taking a look at the ICON 2.5" kits. They use springs to get their 2.5" instead of spacers. They also have several different shock options depending on what you are going to do with the truck and your budget.
Since you have an F250, you will definitely want to get a 4" block kit to level the truck out, or a 5" block kit to have a slight rake. Quite a few people go this route that tow so the truck is level when they are under load.
An adjustable track bar is not absolutely necessary with a 2.5" kit, but will center the axle.
Running 37's with a 2.5" is going to be very tight. I ran 37's on a 4.5" kit and there was slight rubbing. I suggest going with a 35" to be safe.
ICON Stage I 2.5"
ICON Stage 2 2.5"
ICON Stage 3 2.5"
ICON Stage 4 2.5"
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #4 of 9 Old 08-07-2012, 07:40 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
My first F250 I leveled and did not put the track bar bracket in and ended up doing it shortly after since the axle shifted and would not align. Might as well do it now and get it over with.
I have always used the SST kits from ReadyLift. Never had any issues. Also you might want to look at Fox Shocks. I have them on my F350 and they make a huge difference.
DSL_PWR is offline
post #5 of 9 Old 08-13-2012, 10:33 AM
Quoted: 2 Post(s)
Im looking at Carli kits also...
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #6 of 9 Old 08-14-2012, 12:03 PM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Let me know if i can answer any questions... Here is a link to our new leveling kit... Just posted the teaser in our thread!
Carli Suspension - Official Thread
OCVeloMan is offline
post #7 of 9 Old 08-14-2012, 02:10 PM
Quoted: 2 Post(s)
Do you sell the full line of Carli Suspension?
wreedPS is offline
post #8 of 9 Old 08-15-2012, 07:47 AM
OCVeloMan's Avatar
Quoted: 179 Post(s)
Garage
Well, I am Carli Suspension
I have a stocking distributor on here who sells our whole line of product! He should be chiming in shortly.
post #9 of 9 Old 08-15-2012, 09:08 AM
Skyd Ram's Avatar
Quoted: 149 Post(s)
We are one of Carli's largest distributor. Let me know if you have any questions.
George
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
