| 6.4 Exterior Discussion Body and Accessories Talk |
Bilstein level kit??
Got an offer to buy a used Bilstein level kit for $290 shipped. Wondering if that is a good price and if that kit will fit my truck properly. It comes with two 5100 series shocks, two springs, and two 1" blocks for the rear. Does that seem a bit on the high side? I have found similar kits brand new for $345. And even some that have all 4 shocks for nearly the same price. Advice please?
Actually it isnt Bilstein its Donahoe racing now Icon. here is link to what it is
2005 - Current Ford SuperDuty F250 / F350 2.5" Stage 1 System - ICON Vehicle Dynamics same thing but the shocks are Bilstein I guess he cant find 2 of them? ( they are $100 each) so bascialy you are getting a $1035 dollar kit minus 2 shocks but getting 1" blocks I also am sure the kit you are asking about is more than 2.5 inches I think 3.5 cuz I fit 37s tires with zero rub on body It did rub on contol arm but that is rim/tire not lift. ( it was my level kit) |
Bilstein does have a level kit..problem is it isn't complete...you will need a adj track bar, rear blocks and U bolts..you don't want to stack blocks..You will also want castor shims to correct the loss of Castor from the lift.
If you read my post i corrected him on the brand of level also |
Yep not needed for those that don't care if the axle isn't centered...
funny....industry std is do not stack blocks... Now if you bolt a spacer into the spring pack thats different. |
1" block worked with zero problems but not needed I like the back higher than front as you see in my avatar that is the kit I had on. if its a big deal buy a 3inch block to me was not a problem no idea what you are talking about bolting spacer to spring pack? |
So do I need to buy anything else for this kit? U bolts, castor shims, etc? I'm new to all of this. I'm also trying to find the rear shocks to put them all on at once.
I have no clue if he sent you Ubolts or if they were even needed? |
The Bilstein leveling kit includes springs and shocks. It is a very nice kit for the money. If you have a F250, you will need to purchase 4" blocks and U-bolts or just get the 4" ReadyLift block kit. I wouldnt buy one used for $290, you can get them brand new for not much more. Let us know if you would like a quote, we have them in stock, ready to ship.
