| 6.4 Exterior Discussion Body and Accessories Talk |
Air System
I need some input on doing an on board air system. I want to install train horns, rear air bags and have access to air for tires etc... Here’s what I have in mind so far let me know your thoughts or ideas of what you are running.
Train horns - ? Need advice on a good set. Rear bags - Thinking about the Pac brake, not sure about fitting with my 8” lift. Air system - 12 gallon tank with duel Viair 444 pumps. I want to build it so that I can + or – air to the rear bags from the cab with a duel air gauge to show bag psi and tank psi. I want to add a quick connection to each side of the truck to use for tires or what not. I think I can build a nice set up cheaper than if I buy a complete run of the mill system. So any help would be great. Thanks |
Air system
Wow 12 gallons is huge for air horns are you planning on using it for work also?
I know you can buy extensions for air lift 5000's to fit your 8" lift. As for what air horns are best I thought the Siberian express train horns sounded cool. But I guess that's personal preference. I saw a guy on YouTube running them in a jeep with a viair setup. I just installed the medium duty on my 04 crew cab. It has a 2.5 gallon tank and the viair 325 there's room for another pump for the future. It fits great on the passenger frame rail right below the rear door. |
Do you happen to have a part # for the Siberian horns? |
I am also interested in this. I have a set of firestone bags, cab gague controller, and compressor already. I am looking at a train horn and a 10 gallon tank. How are you guys making your hook up for filling up tires and stuff? I want a nice clean professonal look.
Here's my tank and compressor. Right now I just have a coupler on one of the tank ports. I'm routing a line to a regulator I'm installing under my tool box in the near future.
Train horn Jeep with train horn Sent from my Autoguide iPhone app |
[IMG] [/IMG]
How did you make the connection stable in te hole? I was thing of that but couldn't find a beaker to make it solid.
Boy that post sucked. Damn iPhone. How about the, thinking, and bracket.
I haven’t yet; it is still in the planning stages. But this is what I want it to look like when finished.
Sweet let me know what you use. I might just drill a new hole and tap it with ntp threads. Also where are going to mount a ten gallon tank? My 2.5 fit with ease. So if you found a DOT approved 10 gallon it might fit there.
