Front end looks off! - Ford Powerstroke Diesel Forum
Old 05-15-2012, 10:26 AM
I bought my truck about a year ago 2008 250, 35s and i think a 4 inch lift i also notice 2 inch spacers so its higher in the front.i had it all checked out at the ford dealer and they said everything was good! the problem is i notice the hole axle is shifted or is shifting to one side. it looks like about 2 0r 3 inches, the steering is pretty hard any help would be cool thanks
Old 05-15-2012, 10:35 PM
if its lifted check the pan hard bar(trac bar). check if its the stock one with a drop bracket. or if it has an adjustable one then maybe it needs to be adjusted. it should have either of the two listed above.
Old 05-16-2012, 02:53 AM
check the bars like said above. the alignment might be correct BUT if you have a 4 wheel alignment done it will tell you if the front is pushed to 1 side or not.....
Old 05-16-2012, 10:08 AM
ITs the track bar...get an Icon adjustable and you will fix the issue...simple
Old 05-16-2012, 12:25 PM
Thanks guys!!! I checked and there's no adjustment so I'm looking in to getting a adjustable trac bar
Old 05-17-2012, 12:24 AM
Icon and Carli make a real good one, cant go wrong with either. But if i had to do it again id go with carli only because they angle the lower portion that connects to the ball joint in such a way as to not prematurely wear out the ball joint.
Super Duty Suspension News and Engineering for Ford SuperDuty F250/F350 4x4: Ford Super Duty Track Bar End
Old 05-17-2012, 07:03 PM
Thats good info before I make a decision, Thanks Ace
Old 05-22-2012, 09:51 AM
Did you check to see if you have a track bar drop bracket. Most adjustable track bars are good for a truck with up to 4" of lift without a drop bracket. Assuming your truck has a 6" lift then you should be running a track bar drop bracket along with a dropped pitman arm.
