leveling kit and 5 inch blocks??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-29-2012, 03:14 PM Thread Starter
Joerobi1's Avatar
wondering if anyone has done a 2.5 inch leveling kit and 5 inch blocks in the rear. Please post pictures if you have done this
Joerobi1 is offline
post #2 of 13 Old 04-30-2012, 09:36 PM
DUstroker08's Avatar
Here is mine 2.5" top gun customz with a 4" block has slight rake, def no cali look. not sure how much you were wanting to spend but if your wanting to go taller than 4" in the rear i'd look at getting new leafs, someone on here has that ill see if i can find that picture.
H&S, Flo-Pro,Memphis, Westin, Recon, Hatchie Bottom
Fayette County Technical Rescue Team
DUstroker08 is offline
post #3 of 13 Old 04-30-2012, 09:59 PM
heres the photo with the larger rear leafs for 6" lift with 2.5" front
post #4 of 13 Old 05-01-2012, 07:53 PM Thread Starter
Joerobi1's Avatar
why do you go with leafs ? i just saw on a site where they offered 4 inch blocks or 5 inch blocks and i didn't know which one looked better.
Joerobi1 is offline
post #5 of 13 Old 05-15-2012, 05:49 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Go 5". If u go 4", although it will technically be level, it will "look" higher in the front. Seem it way too many times.
Also, if u go with any sort of higher block in the rear and a bigger tire, be prepared for axle wrap and purchase some traction bars.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #6 of 13 Old 05-15-2012, 10:22 AM
Quoted: 2 Post(s)
i did the 3.5" leveling kit from readylift and got the 5" rear block.. rear is about 1/2" lower than the front.. its only noticeable depending on the angle i'm parked at.. otherwise, just riding down the road it looks level. but i might be getting an add-a-leaf to bring it up a little more in the rear.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #7 of 13 Old 05-25-2012, 08:42 PM
Too bad you had to go and sell it!
justin51986 is offline
post #8 of 13 Old 05-26-2012, 02:48 AM
maxharley's Avatar
This is my truck with 5" blocks in the rear and a 2.5" front leveling kit. I like the back a little higher than the front. I hate to pull a trailer and have the back squat down.
2008 F-350 4X4 Lariat Crew Cab Short Bed 6.4 PSD Livewire Xtreme with Innovative Diesel Custom tunes
and a 2002 F-350 4X4 Lariat extended cab 7.3 PSD, 4" lift, six position PHP chip, 4" downpipe, 5" straight exhaust and CAI
. 2004 F-550 4X4 XLT, 6.0 PSD
maxharley is offline
post #9 of 13 Old 05-26-2012, 09:07 AM
I'm in the same boat.. I was thinking 2.5 in the front with the 4 in block, but now I'm thinking 5 in blocks, Can't make up my mind haha
Jimbo33 is offline
post #10 of 13 Old 05-26-2012, 11:52 AM
NCfarmboy's Avatar
Im in the same boat... I have a 250 and ordered a 4" block from Newton. I'm going to run my stock tires for a while, and buy a 2" or 2.5" leveling kit later on. Wanting to run 325's
I can always make my 4" block into a 4.5" later since its steel and I can weld 1/2" plate to it
2014 F-250 KR<><
SCT - Rudys Tunes - Deleted
NCfarmboy is offline
