Help with Mirror - Ford Powerstroke Diesel Forum
Old 04-26-2012, 10:08 AM
Help with Mirror
one of our trucks has the right side wide angel mirror broken, need to replace it but cant figure out how to do it, have replacement part but it looks different...its almost like you need to take the mirror out of the frome it rests in....
Old 04-26-2012, 12:27 PM
I have been looking for a diagram on the mirror with no luck. I wanted to run a set of CB antenna's thru the housing.
I did see a link a while back that stated that you just carefully pry the mirror out of the socket... I can't verify this is correct.
Check with the friendly Ford Service department, mine has been helpful for many things I have worked with.
Cheers
