What is the best way to fix sagging? - Ford Powerstroke Diesel Forum
Old 03-15-2012, 05:06 PM
I got an 8 inch rough country lift and the sagging just bothers me every time I look at it. Rough country sent me the add a leaf but it only looks like it'll add about 3/4 of an inch. What the best way to fix this? The trailer is not lowered in the picture.
Old 03-15-2012, 05:10 PM
Air bags or a larger block would be my guess.
Old 03-15-2012, 05:16 PM
Rough country seems to send blocks that are to small. My 3" lift was the same way. Purchased bigger block
Old 03-15-2012, 05:20 PM
I'll look into a bigger block or bags but the block is pretty big
Old 03-17-2012, 07:31 AM
Im in the same boat brother!! I am considering the air lifter 5000 airbag kit. Just as you said the anti wrap block is pretty big already, and to stack a bigger block would require longer u-bolts. And to get leaf springs well thats a lot of coin!!! Even the trac blocks are only 8" blocks and are expensive!!
Old 03-17-2012, 05:34 PM
way off topic but what size tires you running
Sent from my Galaxy Nexus using AutoGuide.com App
Old 03-19-2012, 09:57 AM
37s on 22s
Old 03-19-2012, 10:01 AM
How much do the airbags cost and will that for sure work? I'm thinking about new leaf springs because I don't like how the leaf springs look themselves not a arch down up down with spacers. Depending on if the add a leaf helps which I'm doing tomorrow
Old 03-20-2012, 04:39 PM
after the leaf
Pictures uneven but it looks like it sits even now
Old 03-21-2012, 07:00 AM
Looks pretty even there! Im running 40's on 22's on mine, but I have a 2" lower coil spacer up front. Add-a-leaf will most likely still leave me sagging. guess Im gonna have to do the air lifter, considering a 3" block and longer u bolts.
