Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 08-09-2007, 08:01 PM
bajasst bajasst is offline
Spacer on rear axle/springs
Can you get a smaller spacer for the rear axle/leaf springs. I would like to get ther rear down 1/2" or so. I want to get the truck in the garage this winter.
Old 08-11-2007, 12:00 AM
99gt 99gt is offline
if you have a 350 i would suggest maybe getting a 250 spacer. If you have a 250 you could try removing a leaf although i wouldn't suggest it.. Keep in mind what ever you do you will have to replace all of the u bolts and center bolts with new ones.
Old 08-11-2007, 12:04 AM
willypscustoms willypscustoms is offline
why i have re used mine plenty of times.
also you could take the stock blocks out and order new ones from 4 wheel parts or ebay and just get the size you want they even sell them at autozone just measure stock ones then get the right size you want.
Old 08-11-2007, 08:37 AM
When "U" bolts are first installed and torqued down they stretch. Reusing an old u bolt will not bring back the proper torque required for clamping.
