coil spring spacers - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-23-2011, 06:51 PM Thread Starter
coil spring spacers
I have a lift that I bought used, I was told it was a 6" but once I got it on I believe its a 4" or 4.5. I would like it a little higher and have been looking on ebay at some coil spring spacers and have seen some 3" but on every website I see 2.5" as the biggest. wondering if anyone has a 3" that they are running or if that would throw the trac bar out of alignment too much?
nltoland is offline
post #2 of 4 Old 02-24-2011, 03:38 AM
Quoted: 36 Post(s)
well from what i just learned- yes the trac bar needs to be addressed. i leveled my 08 f350 and the axle is 1" further on the driverside. with 4" lift i hope you had a drop bracket or adjustable track bar already.......
gwilkrrs is offline
post #3 of 4 Old 02-24-2011, 03:47 AM Thread Starter
Yah I have a trac bar mount already. So I think with the way it is it would be the same as someone with a stock truck putting a 3" spacer on.
nltoland is offline
post #4 of 4 Old 02-24-2011, 05:44 AM
Quoted: 36 Post(s)
i think thats correct. if you add any more lift you will likely need the adjustable track bar installed, as with a stock truck being leveled needs the adj bar to re center axel
gwilkrrs is offline
