any tips for installing newton leveling kit? - Ford Powerstroke Diesel Forum
Old 02-19-2011, 07:35 PM
Send a message via AIM to Duffie112
tomorrow i will be attempting to installing there 2.5" leveling kit and 4" blocks in the back, just seeing who has any tips or tricks to make this go smoothly. thanks
Old 02-20-2011, 04:19 AM
Duffie I'll be installing my Newton kit next weekend. Its been shipped and on the way , My truck is also an 08 F-350. I'm not planning on changing the rear blocks because they are 4" from the factory ( 3 5/8" ) I think. Good luck !!!
Old 02-20-2011, 06:37 AM
i just finished the rear like 2 min ago lol wasnt bad at all, now onto the front lol!
Old 02-20-2011, 07:32 AM
How much difference was there in the rear factory blocks and the ones you installed ?? Did you take any before pics ? would like to see the finished product. Thanks
Old 02-20-2011, 11:36 AM
anyone know what the trick is to install the track bar spacers it lookes like its a pita with the tab u have to hold with vise grips and stuff, any help with this would be awsome thanks
Old 02-20-2011, 02:32 PM
so i when i was installing the rear u bolts and new 4" block i noticed that the new nut for the ubolt is longer than the old nuts, so the threads are only 3/4 of the way through the nut is this right? and the new u bolts are the same length and the stock ones? im confused??
Old 02-20-2011, 02:35 PM
old rule of thumb , min. 3 threads outside the nut.
Old 02-20-2011, 02:39 PM
I assume your using the factory U-Bolts ? Sounds like you may need longer ones. How did you make out on your track bar bracket spacers ?
The Tamed Racing Driver
I would look into getting longer u-bolts. Your, your family, and everyone on the road's safety isn't worth doing it 1/2 a$$.
Thats weird usually they sent long u-bolts and then you trim them
Old 02-20-2011, 03:32 PM
yea im definitly getting longer ones not taking the chance, and the track bar went good easier than i thaught just gonna be carefully thats all
