Highest Lumen H13 bulb? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-12-2011, 08:42 PM Thread Starter
44magnum's Avatar
Quoted: 2 Post(s)
Question Highest Lumen H13 bulb?
Ok so I have a 08 f250 with the h13 halogen bulbs, anyway I have been reading allot and apparently the kelvin rating is simply the color and doesn't have allot to do with how well they light up the night. Lumen's seem to be the key to "brightness" so without changing my stock headlights what is the highest lumen/brightest h13 bulb you can get? Will going with a higher wattage destroy my wiring? Before I did this research I replaced my sylvanias with superstars and didn't see much of any difference. So I'm a believer when it come to people saying higher kelvin rating doesn't mean brighter lights. Thanks
44magnum is offline
post #2 of 7 Old 02-13-2011, 07:15 AM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
You are correct Higher kelvin numbers dont mean more light. Actually the higher you get the less light output you get. For the best color and light output you want to stay right around 5k. As for lumens, did you try the silverstars or silverstar ultra's? Either way they are a slight emprovement over stock, but to really see any sort of great improvement HID is the only way to go. I was in your same boat a year ago, and finally ended up getting the HID's and LOVE THEM!!!
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #3 of 7 Old 02-18-2011, 10:40 PM
2008fx4's Avatar
Phillis Xtreme power +80
2008 fx4 cc sb 6.4 silver/gray over black
all kinds of goodies.........
2008fx4 is offline
post #4 of 7 Old 02-19-2011, 06:14 AM
IA Farmer's Avatar
Are the Philis Xtreme just a standard bulb or do they require ballast like HID's?
2013 F-350 CCSB Platinum
2010 F-250 CCSB Cabelas Edition - Sold
IA Farmer is offline
post #5 of 7 Old 02-19-2011, 06:18 AM
Ryan2011dieselpower's Avatar
put HID in 2011 and was the best thing i ever did
Ryan2011dieselpower is offline
post #6 of 7 Old 04-04-2016, 03:44 AM
3000 lumens with 270H13-s LED plug & play bulbs. No ballast needed. Better than HIDs.
abreau is offline
post #7 of 7 Old 04-28-2016, 03:25 PM
Doss's Avatar
Quoted: 17 Post(s)
I will say, the LEDs are better than the other lighting options, but you still need to match up the housing to the light. The LEDs seem like they work better in an HID projector housing than the OEM halogen reflector housing.
You're not going to get a very bright halogen to replace the factory ones. The options are very limited because pretty much every manufacturer is trying to meet DOT standards.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
