Since rim/tire packages up here in AK are stupid expensive, I'm painting my stock 18's black and buying only tires. So, what would be better and look better on a stock height (maybe level with a 1 1/2" kit one day)?? The factory tires are 33.3"X10 right now. Please give me some help and opinions. Looking at Kumho KL71 btw. Thanks!!
I have 33's on stock wheels and I think they look good. However, I plan to do a leveling kit and will probably go to 35's when I need new tires.
With that said... Personally, I think wider tires that fill out the wheel wells (width wise) do more for the looks than a taller tire. But that is just me. The tires I have right now are 325/60-18's.
My only worry is that if I get 35's but don't get the leveling kit, will I have rubbing issues? Do you or anyone else know if you can fit a 35X12.5 on stock 18" rim at stock height? Sorry for all the questions, I hope to order soon. Thanks again everyone!!
I am not sure if you would have rubbing issues or not with a 35" tire that is 12.5" wide. From the reading that I have done, it sounds like it MAY rub the inner fender and they will need to be tied back, but you won't be rubbing against any hard parts. :dunno:
I have seen it done on stock 05-07 trucks and the 08 and up trucks seem to have just as much maybe even a little more clearance. I think you will be happy with the 35's.
Ive seen 285/75/18 and they look like the perfect fit.......there is a pic around of a sweet truck with this combo,,I will try to find it.....I think he may have a leveling kit though,
the only problem i see with 35's is they might rub bad on the suspension components being that wide on a tire. Do you think they will? I'm not buying aftermarket rims right now. Anymore pics of trucks with 18s and 35's would be great thanks!!
I'm running 35'' Toyos on my just got them this week they look great and no rubbing. I know that the truck is lifted but dont know how much, my guess is 2''. I would really want 37'' tho but its little too late now, can post picks tomorrow for you
My guess is you will not have any issues. I have a 2WD with 35's and only a Daystar leveling kit on. Even with the leveling kit, my truck still sits lower than a 4WD, and I only rub slightly on one side when I am locked all the way to the left. since you are higher, I seriously doubt you will have any issues. I believe I read on here somewhere that they have done it without a lift and have not rubbed.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
