Hey guys i have some lift questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-19-2011, 02:41 PM Thread Starter
Ok guys i have a leveling kit (spacers) and aftermarket shosks that came on the truck when i bought it, and im looking to add a 2 or 2.5in spring lift to it, do i need any drop brackets, brakelines or longer shocks?
dommel01 is offline
post #2 of 3 Old 01-20-2011, 07:25 AM
Skyd Ram's Avatar
Quoted: 150 Post(s)
You will need radius drop brackets, shocks, something to lift rear, etc.
At that point you will be better of getting a true 4.5" lift and just loose the spacers.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 3 Old 01-20-2011, 08:21 AM
TripleE44's Avatar
I agree with Skyd. You'll also have to get something to fix the issue of the front axle shifting, whether it be an adjustable trac bar or a correctly made trac bar drop bracket.
If you can afford to, the 4.5'' lift will be better for what you're wanting, that way you don't have a franken-lift. If not, I'd wait till you can afford to do the whole lift.
11 F250 6.7 CC/SB -- tuned & deleted -- 3.5'' PMF/ICON/Fox suspension, Method Standards, Toyo AT2s
TripleE44 is offline
