Backspacing - Ford Powerstroke Diesel Forum
Old 01-08-2011, 08:00 PM
Backspacing
how much backspacing would i need on new wheels to get my tires to stick out alittle, my truck has 275/65/20 in tires with stock wheels, and bushwacker flares
Old 01-09-2011, 08:30 AM
Stock offset is +40mm. 25.4mm to an inch, so determine how much you want them to move out and subtract it from +40. On stock height and stock tires I wouldn't go much further than +10mm offset, which would move out about 1.2".
Old 01-09-2011, 10:36 AM
Here is mine with 0 offset and 5.00" Backspace. Wheel size is 20" x 9".
Old 01-09-2011, 11:15 AM
how wide r those tires!!?? i didnt know a 0 offset would stick out that much..looks real good
Old 01-09-2011, 11:26 AM
Tires are: 305/55-20 (33" x 12.50"-20)
Old 01-09-2011, 11:32 AM
i always thought i needed a 17x9 with a -12 and 4.5 bs for them to stick out but u have 0 and 5 bs..interesting
Old 01-09-2011, 12:22 PM
I have 20x9" +14 offset which is 5.5" backspacing and they stick out about 1.5" past the fenders with 325/60/20's.
Chris
Old 01-09-2011, 12:55 PM
well the options for the addicts are
-12 offset and 4.5in backspace
18 offset and 5.71in backspace
Which of these would stick out further?
also the diesels im looking at are -24mm offset and 4.56 backspacing, they are used, what if i got the diesels and had them color matched to the truck color?
Old 01-09-2011, 01:15 PM
Chris
Crap good thing I didnt buy new wheels already. Maybe the mickey thompsons will work.the 6.0 and 6.4 have the same axles right?
Old 01-09-2011, 01:31 PM
2005 and newer all have the same axle. The axle is slightly wider than the one used on 1999-2004 trucks. This is why the older trucks can run a deeper dished wheel (4.50" backspace) and the tires only stick out about an 1". Where the newer trucks a 5 backspace with a 20" x 9" wheel sticks out on the front end 2".
