Rize Traction Bars and Amp Steps - Ford Powerstroke Diesel Forum
Old 11-01-2010, 07:19 PM
Will the Rize traction bars work with my Amp Boards or do the front traction bar mounts have to be modified? My 2008 CC SB F250 is at 10" of lift. Thanks.
Old 11-01-2010, 07:25 PM
off topic but, lets see some pis of the truck!!!!!
Old 11-03-2010, 07:25 PM
I'll get some more pics up when I get a chance. Back to topic, anyone have info on rize traction bars amp board combo? Thanks.
Old 11-18-2010, 01:54 PM
i moved the rear idler hinge forward to the next set of holes on my amps to clear my traction bar mounts,works great.
Old 12-01-2010, 04:46 PM
yep what above said,you have to move the amp rear hing forward to the next set of holes and youll be fine
Old 12-02-2010, 08:14 PM
ditto on the above two posts. I did same thing. move to next set of holes and adjust the steps to even out weight distribution when you step on the back portion.
