Adding Stock Fog lights? - Ford Powerstroke Diesel Forum
Old 10-24-2010, 06:10 PM
Served Our Country!
Feedback Score: 3 reviews
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
I know with the older models all you need is the new head light switch in the cab with the fog light option and plug in and bolt up the lights and your done, what about the 08+?
Old 10-29-2010, 02:12 PM
Same. I added them to mine. Harness is there.
Old 10-29-2010, 03:21 PM
Served Our Country!
Thanks man, I looked under the bumper and didnt see any plugs but once I lifted the hood I saw 2 harness ends with plugs in them.. are those the correct ones?
Old 10-30-2010, 02:16 PM
Yes. It's the one on the drivers side. It's attached to the headlight housing. The harness snaps into the holes in the bottom of the bumper and runs over and up and plugs in there. The harness came with all the snaps. All I had to do was push em in, plug it up, install the lights and the switch and they worked perfect.
Old 10-30-2010, 02:59 PM
Served Our Country!
Awesome man, thanks.. I am going to call Ford tomorrow.
Old 11-04-2010, 09:05 AM
Do you have the ford part numbers for the parts that you bought?
I just called ford and of corse the parts guy was no help to me. He was telling me that there was a fog lamp accessory kit that I needed to make this work but that it was not available for my vehicle.
Old 11-06-2010, 02:39 AM
I have had two trucks with fog lamps and never used them (too bright). Save your money. Oh and yes I live in the Central Valley.
Old 11-06-2010, 05:02 AM
Ford OEM Lights - 7C3Z-15200-AA & 7C3Z-15201-AA $55 each or $75 from Ebay
Ford OEM Harness - 7C3Z-15A211 $28
Ford OEM Headlight Switch - (automatic) 7C3Z-11654 SW6455 or SW6454 for regular $43
georider: Most people want fog lights to make the truck look more complete and get rid of those cheap plastic pieces that fill the holes. Plus you may need to explain to most people on here the the Central Valley is in California and gets some of the worst fog in the US. It's called Tule Fog, and I am very thankful that I had fog lights when I used to live there. Plus if they're too bright for you, put a different bulb in it.
Old 11-06-2010, 04:23 PM
If you want it all from one place:
www.partsguyed.com
Old 11-06-2010, 05:53 PM
Served Our Country!
www.partsguyed.com
thanks for the link, I am going to order from them on Monday.
