lowering my f-250 4x4 an inch in the rear - Ford Powerstroke Diesel Forum
Old 09-15-2010, 08:15 PM
Im thinking about lowering my f250 an inch in the back to level it out does anyone have any pictures of this same setup running 35x12.50s on factory 20s
Old 09-15-2010, 09:46 PM
just get a level for the front
Old 09-15-2010, 11:17 PM
i would do that but this is going to be more of a drag truck so i would like to keep it a little lower
Old 09-16-2010, 02:38 AM
a drag truck with 35s?
Old 09-16-2010, 02:42 AM
Why not? Mine ran 13.1 2 years ago on 38s....
Taking out the rear block will more than likely level your truck...but if the rears too low I would add in a 1" solid block OUO makes one..dont do an alum block...they suck
This is a bit lower than your looking to go...but mines 4wd, and on almost 33" tires here
Old 09-16-2010, 04:12 AM
How much do the ouo blocks cost.
Old 09-17-2010, 11:08 AM
i see your point but i just thought it was all about weight i don't want to step on anyones toes i was just curious thank you for your insight
Old 03-15-2012, 06:54 PM
Pahrump, how do you like those 420s'? I am looking to remove my rear block and do 20x10's with 305-50's... Did you use your factory u bolts or did you buy new shorter ones?
Old 03-16-2012, 06:32 AM
I bought some shorter ones cause without my rear block and bottom leaf the stock ones were too short...The 420s hooked pretty well...but only lasted me about 8000 miles...course some of that was premature wear...lol
I have long since changed that combo and even have a different 6.4 now...I rolled that black truck over here a few months back.
Old 03-18-2012, 07:04 AM
Thats too bad,What setup did you go with on your new truck? Im just wondering if the 420s' shook on the highway like my old terra grapplers.
